Stripped Thread
Spoon
Hi
just made the fatal mistake so stripping the thread on my 1998 1.6 A3's oil sump and in desporate need of knowing what options i have
can i get it re-threaded or do i need a new sump if so where from and how much r is there any other options
:readit:
New sump is about £40 from vag parts places, or Helicoil as mentioned above.
helicoil or tap out to the next size up and fit a bigger plug depending on whether there's enough material around the drain.
obviously you'd use a lot of grease on the tap to prevent any swarf entering the sump
thanks for al the advice but i think if i can pic a new sump up for about 40 i do like that idea as it seems like a much better and stronger fix
