PLA 3.0 retrofit complete, require assistance in activating 1 bit
HumzaAdam
London
*PFL S3 automatic with retrofitted VC, MIB2 and updated can gateway.*
Looking for some coding assistance in regards to PLA 3.0 more specifically how to activate 1 bit. Recently upgraded to PLA 3.0 from factory rear sensors only, coded everything up and everything seems to be working as it should. All sensors are functional, sensor display with active guidelines pop up in reverse, park button on hazard panel works as it should and front and rear buzzer sound as expected, however park assist does not work and I believe this is because I was not able to code the instrument cluster. Out all the coding changes necessary for PLA 3.0 I was not able to activate bit 0 in byte 13 at address 17-instruments. When I attempt to make the change VCDS throws error 31 request out of range. I’ve looked at scans from other cars and scoured the internet for the correct coding procedure and I’ve narrowed it down to what I have below. Cars with PLA 3.0 and a virtual cockpit have byte 13 bit 0 checked. Does anyone know why I cannot activate this bit and how I can activate it? I’ve provided a full auto scan, you’ll notice I have missing messages in 03-abs, 10-pla, 5f-infotainment and control module coded incorrectly 17-instruments.
PLA 3.0 coding
03-ABS
Byte 24 bit 5
Byte 26 Bit 4 and Bit 6
17-Instruments:
Byte 13 Bit 0
Steering Assist-44:
Byte 0 Bit 1: Park/Steer Assist active/installed
PLA-10
Byte 0 Bit 1-2: 02 System Type: Park/Steer Assist
Byte 1 Bit 4: Limited Operation available
Byte 1 Bit 5: Vehicle Path Display active
Byte 1 Bit 6: Wheels Speed Sensors with Rotation Direction Detection installed
Byte 2 Bit 0-1: 02 Optical Parking System (OPS) with 360° Illustration active
Byte 2 Bit 2-3: 04 Display and Operating Protocol (BAP) v4.0 active
Byte 2 Bit 4-5: (I don't have a rear view camera as of yet)
Byte 3 Bit 4: Automatic Park Assist Activation enabled
Byte 4 Bit 0: Trunk Monkey (PR-UFO) locked away
Byte 4 Bit 4: Automatic Transmission installed
Code:
Tuesday,31,May,2022,18:59:49:28437
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.4 (x64)
Data version: 20220407 DS337.0
www.Ross-Tech.com
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 22 42 44 47 52 55 5F 65 A9
          BB BC
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259     HW: 06K 907 425 A
   Component: 2.0l R4 TFSI  H09 0007
   Revision: --H09---    CVN: 8A76B81F
   Coding: 0A1D00322426010B2000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TFS0218V0906259 001009
   ROD: EV_ECM20TFS021_AU37.rod
   VCID: 7DFA7A31EC9E7B67A4-8028
   VINID: 9D196AAAA22621544118408104375AD5F7
No fault code found.
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4932
   Revision: 05852204    Serial number: TFK01402261044 CVN: 0000ACE0
   Coding: 0014
   Shop #: WSC 04742 780 00200
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 1F4660B906D2C977D6-804A
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 AA    HW: 5Q0 907 379 G
   Component: ESC           H31 0457
   Revision: 00000000    Serial number: 606040000019E3
   Coding: 32F193A254262A700379070141C4694CC92A54C0E08296F7224150080608
   Shop #: WSC 50786 004 104857
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
   ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod
   VCID: 7BFE7429F28A75579A-802E
1 Fault Found:
8196 - Databus
          U1121 00 [009] - Missing Message
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 18
                    Date: 2022.05.31
                    Time: 18:50:55
Address 08: Auto HVAC (E87)       Labels:| 8V0-820-043.clb
   Part No SW: 8V0 820 043 AL    HW: 8V0 820 043 AL
   Component: AC Automat    H03 0161
   Revision: 20001000    Serial number: 00000001975392
   Coding: 03100014000000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008026
   ROD: EV_AirCondiFrontVaAU37X_008.rod
   VCID: 7CFC7735F784726F93-8028
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0003
   Serial number: 35288A17000000000001
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011406501340
   Coding: 07141D46C24106FD03844004B31C07A80000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 012001
   ROD: EV_BCMBOSCH_012.rod
   Wiper motor control module:
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 140224  041 0580
   Serial number:         140228005258
   Coding: 0A47F7
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0002
   Serial number: 22354391
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 08 04 2017  00000492
   Anti-theft alarm system sensor:
   Subsystem 4 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY140342CHQ
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000059025213
   Sunroof control module:
   Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO27328477
   Coding: 901E00
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417617215
   Coding: 0370061051
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 50A4F3850B8C260F1F-8004
1 Fault Found:
12656926 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 112256 km
                    Date: 2022.05.31
                    Time: 18:50:56
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R05NX8.
   Coding: 98CCC0000C0000005C5400CA00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 4B9EE4E9E2AA05D76A-801E
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 480 001 103 14
   Component: SideSensor_Df  001 0887
   Serial number: 357670000009D7A0FE0A
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 480 001 103 14
   Component: SideSensor_Pf  001 0887
   Serial number: 358670000001D7A0FE03
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 480 400 703 14
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502B1142B1C2729%
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 480 400 703 14
   Component: SideSensor_Pr  001 6149
   Serial number: 3526502C712F629382BF
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 400 602 14
   Component: FrontSensor_D  001 6149
   Serial number: 3556502C312AB1B440ED
   Coding: 2D2D2D
   Driver's side crash data pedestrian protection:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 502 14
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502C3142B1C4120Z
   Coding: 2D2D2D
   Passenger's side crash data pedestrian protection:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 402 14
   Component: PedP_Sensor_P  001 6149
   Serial number: 22965029F142B1C461BH
   Coding: 2D2D2D
   Center pedestrian protection crash sensor:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 502 14
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502BD142B1C4929B
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 8V0 953 521 BP    HW: 5Q0 953 549 C
   Component: Lenks. Modul  002 0110
   Revision: --------    Serial number: 12031408490117
   Coding: A418
   ASAM Dataset: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 09121EE1A85657C798-805C
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790 A    HW: 8V0 920 790 A
   Component: FBenRDW       H16 0066
   Coding: 202D08C22A8006000101E8041000001000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001027
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 3A70B12DBD308C5FC1-806E
1 Fault Found:
13636608 - Control Module Incorrectly Coded
          U1014 00 [009] - -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 112256 km
                    Date: 2022.05.31
                    Time: 18:50:54
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1265
   Revision: --------    Serial number: 0001672554
   Coding: 030100042B085A005B0002681C0B00000001000000000000000000000000
   GVL: 01DC3C1000000100400C10000000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 013020
   ROD: EV_GatewLear_013.rod
   Generator:
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20180328091350 30874
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 8533342703
1 Fault Found:
1548 - Data Set Implausible
          B2012 00 [009] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 112256 km
                    Date: 2022.05.31
                    Time: 18:50:54
                    Terminal 30 power supply: 13.2 V
                    Terminal 15: On
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 81A 857 511 A    HW: 81A 857 511 A
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 0404010700000100010001
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 2648755D598818BF95-8072
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00014.02.14
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002001
   ROD: EV_AllWheelContrHA1VW37X.rod
   VCID: 4688D5DDF9C8F8BFB5-8012
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 B    HW: 5Q0 959 593 B
   Component: TSG FS        020 0025
   Serial number: 01031403111897
   Coding: 005D8E205C01040000001002
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 4084C3C5DBECD68F8F-8014
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8303
   ASAM Dataset: EV_SteerAssisMQB 010031
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 356AA211942E63272C-8060
Address 47: Sound System (J525)       Labels:| 81A-035-466.clb
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAH5F014EY3
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 244C6F552FB4EAAF8B-8070
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 B    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0025
   Serial number: 28021401101358
   Coding: 005D86205E01040000001002
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 3F86C039A612A977F6-806A
Address 55: Headlight Range (J745)       Labels:| 7P6-907-357.clb
   Part No SW: 7P6 907 357 B    HW: 7P6 907 357 B
   Component: AFS-ECU       H01 0040
   Revision: --------    Serial number: --------------
   Coding: 01AE00002B230200
   ASAM Dataset: EV_HeadlRegulLEDAFSMQB 001001
   ROD: EV_HeadlRegulLEDAFSMQB.rod
   VCID: 3E78BD3DA118A07FFD-806A
   Left LED Headlamp Power Output Stage 1:
   Subsystem 1 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7530
   Coding: E00100
   Right LED Headlamp Power Output Stage 1:
   Subsystem 2 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7530
   Coding: E00100
   Left Headlamp Power Output Stage:
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7000
   Coding: E00100
   Right Headlamp Power Output Stage:
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7000
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels:* None
   Part No SW: 8V1 035 035 E    HW: 8V1 035 035 C
   Component: MU-P-LND-EU   055 1326
   Serial number: A698C0LB027280
   Coding: 017353010000000011111102000A00312F0027E701700100FE
   ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
   ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
   VCID: 346C9F159F547A2F1B-8060
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 802 TM    HW: -----------
   Component: ECE 2021/2022  --- 0192
   Serial number: --------------------
   Multimedia System 1:
   Subsystem 2 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0013
   Serial number: AUZ8Z9EY200J56
   Multimedia system control head:
   Subsystem 3 - Part No SW: 8V0 919 614 BJ    HW: 8V0 919 614 BJ
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL124011800050846
   Compact disc data bank:
   Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1017
1 Fault Found:
7202 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 112256 km
                    Date: 2022.05.31
                    Time: 18:50:58
                    Voltage terminal 30: 13.5 V
                    BAP-BAP_Function_ID: 02
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 8S0 907 273     HW: 4M0 907 273 B
   Component: RDKHUFAU736   H06 0002
   Serial number: 40000000014798
   ASAM Dataset: EV_RDKHUFAU736 002007
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 77F66819CEA25137FE-8022
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 140225201560
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0025
   Serial number: 03031403110153
   Coding: 004D86204001040000001002
   ASAM Dataset: EV_DCURearDriveMAXKLO 006003
   ROD: EV_DCURearDriveMAXCONT.rod
   VCID: 4280C9CDD5E0C49F99-8016
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      020 0025
   Serial number: 03031401100159
   ASAM Dataset: EV_DCURearPasseMAXKLO 006003
   ROD: EV_DCURearPasseMAXCONT.rod
End-------------------------(Elapsed Time: 05:30)--------------------------
Im sorry mate, bit off topic, but can you share your progress and wiring? In also interested in doing this mod but have no ElsaWin for my model (facelift).
Verzonden vanaf mijn iPhone met Tapatalk
No worries mate, it was actually your guide on the 8P that piqued my interest in PLA haha. Since you've done it once, you'll be fine with doing it on the 8V as the process is near enough identical (running loom, cutting holes, etc). I'll PM over the wiring diagrams, let me know how you get on.
*PFL and FL wiring is the same*
Reactions: henkkeumus
update:
There seems to be some differences between
ASAM Dataset: EV_DashBoardVDDMQBAB and EV_DashBoardFPKAU37X
FPK seems to have byte 5 > bit 4 checked
VDD seems to have byte 13 > bit 0 checked
You would have to code your cluster according to that.
As for the missing messages in 03 and 10, that's because my current ABS pump does not support PLA 3.0.
Best to upgrade ABS to a 3Q0 for maximum compatibility for this and potential future retrofits.
Nice one mate. Looking to do this very soon and just trying to gather as much info as possible at the moment.
If you're after anything specific shoot me a PM.
Reactions: Gazpot0111645
Here is mine. pla 3.0 on pfl.
Look at byte 24 of abs..
Could be the cluster doesnt need to be coded for pla3.0 as the mmi is the pla 3.0 display... Also remove pla 2.0 coding
  • Log-NF914X-WAUZZZ8VXEA066927-22900km-14229mi.txt
I already solved this. The instruments coding was byte 5 > bit 4 for me and I had to change my ABS pump as my one did not support PLA 3.0. Bought a new pump on eBay that supports everything for £20 and it took an afternoon to fit.
81688F6C 10E2 423E B482 48B22B7B7027
Lane assist and side assist is also nice upgrade.
ACC
Lane assist
Side assist
KESSY
Are next and I'm going to do them all at once because I don't want to keep dismantling the car.
Once those are done, I'm maxed out. I'll have everything apart from some miscellaneous spec such as electric trailer hitch, ski load, etc, things I will never do.
ACC
Lane assist
Side assist
KESSY
Never maxed out.. Got matrix front?? dynamic rear? Direct tpms? Active exhaust? 220v outlet? dual usb in rear? Colour interior lights controlled by bcm? Google maps working? VC retrofitted? Elektric rear boot opener?
Super late reply, life got busy so I've barely been active on here in the recent months.
To answer your questions, yes there's still much to do before being truly maxed out but as I mentioned I'm not interested in miscellaneous spec like dual USBs etc (they're slower at charging anyway). Don't have Matrix LEDs as I've got a PFL, unless I plan on doing a full exterior facelift I wont be doing that. I do have LED headlights though. Got direct TPMS, colour changing interior lights was interesting but I hit a dead end with that. Went with the extended interior lighting pack instead (white led lights in door trims controlled via MMI). Got VC, Electric rear boot isn't an option on the 8V from what I know and google maps is work in progress. I crimped up antenna pins and installed LTE antennas in the rear bumper months ago but never went further (pics below). I haven't touched the car in months and now that winter is here I don't fancy working on the drive, I might wait till it gets warmer before I start again. For now I'll collect the parts for the above retrofits in time for spring/summer.
IMG 0551
IMG 0553
IMG 0614
IMG 0617
Reactions: Vas S3 8V sedan and pxuL
View attachment 260818View attachment 260819View attachment 260820View attachment 260821
If you need help with acc let me know.
I installed fl lane assist, acc/pacc.
Got my car facelifted with matrix (hell of a job but worth it!)
For sure!
I know the wiring and install process (I’ve got wiring diagrams and ELSA) I just can’t decide on which radar to get. Old LRR radars only have component protection but the new MRR ones have component protection and FEC. Because I have VC I’ve read that LRR isn’t 100% compatible, the image on the display doesn’t move. Also I’ve read you shouldn’t mix different generations of ACC and lane assist camera (I have a facelift camera) I would happily go for a 3rd gen radar but the getting the FECs is a pain. Any advice?
For sure!
I can help you with the fec codes. And if you still want lane assist: get facelift for all modules!
And facelift windshield. PFL round radars are easy but also pricy and not fully compatible with vc. (image on vc only moves when acc is off, on golf it does move)
Can sent you all needed to activate pacc /acc
I went for the 3qf radar. It isnt so hard. (but need access to odis e&s)
First thing is to DO NOT REMOVE CP as you will need cp active to install x firmware.
X (experimantal) firmware is the firmware that enables you to add the fec .
After flashing you need remove cp.
Next you need to figure out what fecs you want on the car. Depending on manual/dsg/vc
You can choose 4 fec codes. And enable them. Remember these codes as youll need them later while coding.
After this youll need to create svm code and upload these to car.
Check if all conditions are met.
Flash regular firmware.
Code car.
Done.
Buy cable sets for acc and lane assist from ali.
You also need acc /la stalks, facelift also works, and (you already have this bcz you have pla) new abs sensors in rear.
For pacc, in some countries is doesnt work.. dont know your country..
Reactions: HumzaAdam
Which one is a 3QF radar?
All I can see on ETKA for 8V is 5Q0907541 for LLR and 5Q0907561 for MRR
I went with 5Q0907561N as it has come from the same car and the price was great.
Do you have traffic sign recognition?
I'm gathering the all the parts now as I'm managing to find them for really cheap.
I was ordinally going to wait until summer but now I'm aiming to finish it all by the end of the year.
2Q0907572 , 3Q0907572, 3QF907572, 5QF907572, 5Q0907572 and 3QF907561 are the ones you can use for x firmware to upload fec. 5Q0907572 does NOT support PACC...
Not sure if your recent purchase is suported by x firmware... At most it will do acc as no more coding is inside.
X firmware loads vw firmware, so in odis you have to change session to vw37 to code it.. Hope you got someone who has odis..
10009001 MRR-Paket 1: ACClow (Basis-ACC) + FrontAssist inkl. CityANB
10009002 MRR-Paket 2: ACClow (ACC FTS) + FrontAssist inkl. CityANB
10009003 MRR-Paket 3: ACClow (ACC S&G) + FrontAssist inkl. CityANB
10009004 MRR-Paket 4: FrontAssist inkl. CityANB (без ACC)
10009005 MRR-Paket 5: CityANB (без ACC)
10009006 MRR-Paket 6: ACChigh (Basis-ACC) + FrontAssist inkl. CityANB
10009007 MRR-Paket 7: ACChigh (ACC FTS) + FrontAssist inkl. CityANB
10009008 MRR-Paket 8: ACChigh (ACC S&G) + FrontAssist inkl. CityANB
10009101 ACC-Funktionserweiterungs-Paket "predictiveACC"
10009102 ACC-Funktionserweiterungs-Paket "StauAssistent" (Ассистент пробок)
10009103 ACC-Funktionserweiterungs-Paket "predictiveACC & StauAssistent"
10009201 AWV-Auspraegung "AWV1,2 - Warnung nur visuell & auditiv" (предупреждение только визуальное и
слуховое)
10009202 AWV-Auspraegung "AWV1,2"
10009203 AWV-Auspraegung "AWV1,2,3"
10009204 AWV-Auspraegung "AWV1,2,3, vFGS
10009205 AWV-Auspraegung "AWV1,2,3, vFGS, vRFS“
10009300 AWV-Funktionserweiterungs-Paket "Elektronische Parkbremse"
10009301 AWV-Funktionserweiterungs-Paket "EmergencyAssist"
10009302 AWV-Funktionserweiterungs-Paket "Abbiegeassistent"
10009303 AWV-Funktionserweiterungs-Paket "AWV-Gegenverkehr"
10009304 AWV-Funktionserweiterungs-Paket "Abbiegeassistent & AWV-Gegenverkehr"
10009305 AWV-Funktionserweiterungs-Paket "EmergencyAssist & AWV-Gegenverkehr"
10009306 AWV-Funktionserweiterungs-Paket "EmergencyAssist & Abbiegeassistent"
10009307 AWV-Funktionserweiterungs-Paket "EmergencyAssist & Abbiegeassistent & AWV-Gegenverkehr"
10009500 Verkehrszeichenerkennung (VZE)
10009600 Vorrausschauender Fussgaengerschutz (VFS) - FCWP
Here are the fec you can choose from. Max 4.
The fec codes are impemented on your cars equipment.
900x range:
ACC fts (follow to stop) has no use for manual gb car.
ACC S&g (stop and go) same
So for a manual car the first fec is acc basic. ( 9001 or 9006) Choose best option..
910x range:
Pacc can only be used with 3q front camera. If not installed skip fec.
Stau assistent (traffic jam assistent)can be used with both, but not sure.
920x range:
Autonomic braking. (also depends on camera.) 2q camera can detect crossing pedestrians and bikers...
930x range
EmergencyAssist
Abbiegeassistent (corner assistence)
AWV-Gegenverkehr (oncoming traffic)
Whatever fec you choose, remember and write down the last 3 ditgets. 1 ditgit ( 9x00) is the place you need to enter the 3th (900x) ditgit in coding.
Ahh ok, appreciate the help.
The seller I bought the radar from accepts returns so if I have any issues I can return it and get a 3QF one.
What is the difference between Audi traffic jam assist and stop&go?
Better change it to 3qf...
hello I would also like to install pla 3.0 but I have an abs 5Q0 pump can you give me the reference of your pump please.
there are many references on etka and they often don't support the same options. your help would be greatly appreciated thank you
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G from factory, upgraded to
Part No SW: 5Q0 907 379 CK HW: 5Q0 907 379 G (same pump)
On mine it works, but car is manual..
Reactions: Kevin49400
I swapped out my my original pump 5Q0907379AA with 3Q0907379AB which supports everything and was a free upgrade. Bought the new pump for £30 and sold my old pump for £30.
Hi mate, yeah I finished off all remaining retrofits except KESSY.
I have working ACC with pACC, TJA and TSR.
IMG 1254
@HumzaAdam Hello, I have a 2017 model A3 8V Sportback with front and rear parking sensors. I want to upgrade to PLA 3.0. Can you help me with this?
