Audi a3 8p 2.0 tdi Vcds coding help please
Ridwan
Hi all,
Was wondering if someone can help please.
Background: My audi a3 cluster suddenly died, I tried everything from checking battery ground cables, to changing battery, new key battery, checking fuses, disconnecting battery, checking cluster connection etc. Eventually I took the cluster to be repaired, and soldering was repaired in the cluster. (car would not start, it would start for a second and die)
I plug in the repaired cluster, and it finally powered up, allowing me to start the car successfully. Only problem was, the steering wheel had no power steering, and abs and esp light, and steering wheel light were permanently on. Red steering light and yellow abs and esp.
After playing about on vcds, I changed adaptations on 44 steering assist, at first I cleared the codes and it made no difference. I tried to do the calibrations on the steering wheel (centre, full lock both ways) even drove for 1 hour and no difference. Then randomly I plugged it in again and cleared the codes and finally I had my power steering again!
Unfortunately the abs and esp light is still on. I have tried to do basic settings under 03 for the G85, however it comes up as error each time I select on/off. I don't know if it is an issue with the long coding on the abs, or what the issue could be, could any gurus please give me any ideas to try on vcds? Maybe it needs a new code?
Below is the full scan from vcds.
VIN: WAUZZZ8P79A008555 License Plate:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WAUZZZ8P79A008555 Mileage: 233550km-145121miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BQ HW: 03L 906 022 BQ
Component: R4 2,0L EDC 0000SG 3066
Revision: --H01--- Serial number: AUX7Z0H5FNQ0C0
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 75E154D31CC13F2162-8020
VINID: 9D196AAAA2201C9440008145146BC23099
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 1342401209220002C81002E9901E00823800
Shop #: WSC 06314 000 00000
VCID: 74E769D7D7BB262955-8020
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Mileage: 233557 km
Time Indication: 0
Date: 2022.03.04
Time: 14:48:09
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 338
Count: 50176
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH08 0100
Revision: 000376 Serial number: 8P0820043BG
Shop #: WSC 00000 000 00000
VCID: 72EB6FCF6DAF281947-8026
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008587242
Coding: 1B883F81F01410807D00001F00000000000A4E076406440F002800000000
Shop #: WSC 38100 001 00001
VCID: 489FED273BB3F2C9C9-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 38100
4 Faults Found:
00988 - Lamp for Brake Light; Right (M10)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Mileage: 233524 km
Time Indication: 0
Date: 2022.02.19
Time: 07:51:00
Freeze Frame:
ON
Voltage: 13.80 V
OFF
ON
OFF
OFF
ON
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 233525 km
Time Indication: 0
Date: 2022.02.19
Time: 07:52:00
Freeze Frame:
ON
Voltage: 13.85 V
OFF
ON
OFF
OFF
ON
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 233525 km
Time Indication: 0
Date: 2022.02.19
Time: 07:52:00
Freeze Frame:
ON
Voltage: 13.85 V
OFF
ON
OFF
OFF
ON
00987 - Lamp for Brake Light; Left (M9)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 40
Mileage: 233524 km
Time Indication: 0
Date: 2022.02.19
Time: 07:50:00
Freeze Frame:
ON
Voltage: 13.85 V
OFF
ON
OFF
OFF
ON
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303030374A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4999E823E8B90BC1D6-801C
Crash sensor for side airbag: driver side:
Serial number: 3572DRB40000780518FU
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3582DRB400007704DB0T
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 35128RB400003DBFC91$
Passenger side rear thorax airbag crash sensor:
Serial number: 35228RB400003DDC23AW
Crash sensor for front airbag: driver side:
Serial number: 35547RB400003CEBDF05
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400003CEBDFFL
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002012
VCID: 4189F0031889C3810E-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H15 0820
Revision: D0H15004 Serial number: 2245H004001749
Coding: 0004404
Shop #: WSC 00011 067 57207
VCID: 397998E370599B4146-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H-- 0202
Revision: H-- Serial number: 00000000000000
Coding: E9807F061002020103
Shop #: WSC 65432 786 678678
VCID: 356194D35C417F21A2-8060
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H15004 Serial number: AUX7Z0H5FNQ0C0
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000692
VCID: 4385FA0B0295D1911C-8016
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.078 H08 1901
Shop #: WSC 02069 000 90108
VCID: 366393DF41477439AB-8062
2 Faults Found:
02546 - Steering Limit Stop
Freeze Frame:
Mileage: 233550 km
Temperature: 16.0°C
Voltage: 13.90 V
Voltage: 13.70 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D098F0FCC9FC637
Shop #: WSC 06314 123 12345
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674802666729
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000692
VCID: 4487F917079BD6A925-8010
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H02 0270
Revision: 00H02000 Serial number: AUZ1Z3H8929892
Coding: 0310211
VCID: 3F8DF6FB6E7DB57178-806A
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
2 Faults Found:
00098 - Rear Left Central Locking (Safe) Motor (V163)
00930 - Locking Module for Central Locking; Rear Left (F222)
008 - Implausible Signal - Intermittent
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 428BFF0F1D8FD89917-8016
End-------------------------(Elapsed Time: 02:04)----------------
Complete the basic setting, then do steering limit & all will be fine.
Reactions: Ridwan
Thanks NHN, I followed the basic settings for 03 abs, when I select basic settings on 060, it comes up as error everytime! Then followed by yellow steering light which I then need to recalibrate the steering wheel which gets rid of it.
Any idea why it always comes up as error?
Solved, did basic settings on channel 25, 26, thanks to pevag!
All errors cleared. Finally.
