folding mirrors
We've done this for 8p clients, if interested, then ping me a WhatsApp, prerequisite you have electric folding mirrors already, of course if you don't, we can fit these too.
It can be done but you'll need VCP, can't be done with VCDS
They will fond if you long press the lock button, like when the windows close. They can unfold either when opening the drivers door, or when the ignition is turned on
Hi mate, where are you based and can you pm with a quote? Cheers
Only with specific modules.
Folding mirrors when flashed with vcp will lock on long press on key fob as u said but they only unfold when key is put into ignition not when door opens .
It can be either. I have done both to TTs and Golfs. Any Gen3 door module should be compatible so that includes A3s depending on the module
Reactions: NHN
You can code either with door open or via ignition with vcp bud
My bad mate never knew they can be coded to unfold when door is open . Will need to stick my cable on and see if i can change mine as my drivers door module P has been flashed with Vcp .
Maybe it has to be done when using Vcp or can i change it using my Hexv2 cable do you know
VCP I'm afraid, VCDS cannot change the eeprom. OBD11 can I think but I don't have that. I have a guide on the TT Forum, I'll link it when I'm home. Are you near London?
Note near london mate many many miles away . Will just have to leave it the way it is then , unlock on ignition . Cheers for reply
Rough price on replacing motor and coding? Was quoted £250 at a garage:puke:
666
16K
680
DOB
719
