Tyre pressuress
KXL
Well-Known Member
London
Do all of your A3s show recommended tyre pressures as (for 3 passengers some luggage) as 36 / 36 PSIs?
I noted that it shows all variety of tyre sizes from 205/55 R16, 225/45 R17 (mine) and 225/40 R18s as the same pressures. Surely that can't be right? I might look again, as not sure if they showed any R19s.
Had a Seat Leon 2.0TDI that weighed more and it was 32 / 29 PSI, and a Volvo V40 even heavier still and was 33 / 33 PSI.
It also specifies the "code" for the tyre e.g. 91V/91H/92Y etc. which can be found on the tyre itself.
As an example: mine is 92Y XL, so I need to use 36/36psi or 39/39psi for higher load.
I had a closer look at mine (30 TFSI MHEV) running 225/45 R17s and while the 3 passenger 1 luggage is the same, the fully loaded values were 36 fronts and 39 rears and not like yours 39 / 39. Is yours a TDI by any chance?
Mine is 35TFSI MHEV with 225/40 R18 (92Y XL as shown in the image in my prev. post), Michelin Cinturato if that's relevant.
Looks like I've got to look again at mine, didn't notice if I had a 2nd row which in your case 'highlights' the wheel spec fitted to the vehicle (at least at factory). Mine are also Pirelli Cinturato P7s.
Reactions: DreamInCode
Yap that's Pirelli Cinturato p7 and NOT Michellin. Thanks for correcting the brand .
Interestingly on my tyre pressure sticker, it only shows the top part, and not the 2nd lower part (car specific wheels fitted). Also fully loaded is only shown as 36 / 39. Maybe the light 1.0 up front has something to do with the fronts only needing 36 even if fully loaded.
Btw, what is M+S all season tyres? or winters?
