Hello guys so recently I ve got a vcds and finally done properly coding to my folding mirrors retrofit . BTW I pressed scan and alot of fault codes appeared around 10 I think. I don't even know if it's dangerous or not. I am sure it isn't from me . Some months ago I left my car to various " genius " and probably they got it messed up . The thing I noticed that isn't working on the car a while now is remote closing/opening of windows...
Please someone who knows help me to fix all this ...
I will post the codes below. Thanks
Thursday,03,June,2021,18:03:58:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 21.3.0.0 HEX-V2 CB: 0.4545.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: ---------------------- License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 42 44 52 55 5F
VIN: ------------------------ Mileage: 149172km-92691miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CRBC) Labels: None
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5520
Revision: 83H22---
Coding: 021D001A032401082000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: 7AADF2F55C5CA70BC17-802E
4 Faults Found
7150 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 37 °C
Intake air temperature: 36 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.300 V
Unlearning counter according OBD: 40
17158 - Databus
U1123 00 [032] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 149153 km
Date: 2021.06.03
Time: 14:57:59
Voltage terminal 30: 12.320 V
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: 0.000 m/s²
17262 - Terminal 30
U140A 00 [032] - Open Circuit
[Terminal 30Open circuit]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
Engine control module reset status-Bits 0-7: 0
Limitation: torque: 0.0 Nm
Limitation: accelerator pedal: 0.0 Nm
Cruise Control System (CCS): status-Bits 0-7: 0
Accelerator pedal travel: raw value: 0.00 %
Engine torque: -500.0 Nm
Generator: load signal: 0.00 %
4629 - ECM Power Relay Load Circuit
P068A 00 [032] - Opens Too Early
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Starter control: Interlock- or P/N-signal-Bits 0-7: 0
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0D9 300 040 N HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4305
Revision: 03252204 Serial number: TFK01403011406
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 221DEA95944C0FCBB97-8076
No fault code found.
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 6067400000073C
Coding: 12F162A224270A6C0177060841CB294846245080608294F2026100788608
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod
VCID: 7BA3F7F153669E03DA1-802E
5 Faults Found
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 184
Mileage: 148388 km
Date: 2021.03.23
Time: 00:00:15
16390 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 184
Mileage: 148388 km
Date: 2021.03.23
Time: 00:00:25
32830 - Parking Brake Motors
C10E1 29 [008] - Signal Implausible
[IPB-Actuator: Actuator state UNKNOWN]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 0 km
Date: 2014.03.28
Time: 00:00:18
32928 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[IPB: Supply Voltage below undervoltage threshold]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 184
32948 - Comfort limitation
C10D7 00 [008] - -
[IPB-Miscellaneous: EEPROM data failure]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Date: 2000.00.00
Time: 00:00:00
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000273064
Coding: 03000104002001011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X_008.rod
VCID: 33331FD13BB69643421-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: ED784C17000000000001
5 Faults Found
328964 - Motor for Front Air Distribution Flap
B1091 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 183
Mileage: 148083 km
Date: 2020.10.20
Time: 14:24:32
Voltage terminal 30: 11.7 V
Inside temperature: 19.2 °C
Outside temperature: 19 °C
Front air distribution flap: actual value: 0
Front air distribution flap: actual value: 95.0 %
Air distribution door front - Specified value: 101
329479 - Position Sensor for Fresh/Recirculated Flap Motor
B109B 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 171
Mileage: 148676 km
Date: 2021.05.06
Time: 13:34:43
Voltage terminal 30: 12.9 V
Inside temperature: 39.6 °C
Outside temperature: 30 °C
Fresh air/recirculating air/back pressure door specified value: 859
Actual value for fresh air/recirculation air flow flap: 100.0 %
Actual value for fresh air/recirculation air flow flap: 979
329988 - Motor for Defroster Flap
B1090 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 183
Mileage: 147918 km
Date: 2020.10.18
Time: 10:39:48
Voltage terminal 30: 14.8 V
Inside temperature: 18.2 °C
Outside temperature: 18.5 °C
Defrost door - Specified value: 54
Defroster flap: actual value: 0
Defroster flap: actual value: 0.0 %
1048836 - Blower Output Reduction due to Energy Management
B10CE 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 183
Mileage: 149153 km
Date: 2021.06.03
Time: 13:49:27
Voltage terminal 30: 11.3 V
Blower reduction: No switch-off: no reduction
459020 - Databus
U1121 00 [008] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 183
Mileage: 148319 km
Date: 2021.03.19
Time: 12:41:57
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011407702259
Coding: 04041A46C24120DD43A44004001C07A80400000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_012.rod
Wiper motor control module:
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119
Component: WWS370 140313 041 0580
Serial number: 140314122636
Coding: 0A47F7
Light switch:
Subsystem 2 - Part No SW: 8V0 941 531 J HW: 8V0 941 531 J
Component: E1 - LDS MQB H05 0032
Serial number: 12 12 2013 00000450
Humidity sensor: interior:
Subsystem 3 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20692804
1 Fault Found
549141 - Databus
[TSG_BT_01 Datenbus fehlende Botschaft]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 183
Mileage: 149153 km
Date: 2021.06.03
Time: 13:30:19
Address 10: Park/Steer Assist (J791) Labels:* None
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831408402551
Coding: 0000040011
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_002_VW37.rod
VCID: 382928FD22D0751B773-806C
2 Faults Found
13637120 - Databus
U1123 00 [008] - Received Error Message
[Parkbremse - EPB_01.EPB_Status - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 184
Mileage: 149153 km
Date: 2021.06.03
Time: 14:55:29
13637426 - Databus
[ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 184
Mileage: 148388 km
Date: 2021.03.23
Time: 00:00:15
Address 15: Airbags (J234) Labels:* None
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R05TJ6R
Coding: 98CCC0000C0000005C540000004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4BC367314346EE832A1-801E
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 001 903 14
Component: SideSensor_Df 001 0887
Serial number: 35767000000A85603F0W
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 480 001 903 14
Component: SideSensor_Pf 001 0887
Serial number: 358670000002A5603F0R
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 401 803 14
Component: SideSensor_Dr 001 6149
Serial number: 3516502C5142B1B2D3BC
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 401 803 14
Component: SideSensor_Pr 001 6149
Serial number: 3526502C3142B1B492EB
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 400 602 14
Component: FrontSensor_D 001 6149
Serial number: 3556502A313013F5A26%
Coding: 2D2D2D
Driver's side crash data pedestrian protection:
Subsystem 6 - Part No SW: ----------- HW: 480 402 502 14
Component: PedP_Sensor_D 001 6149
Serial number: 2286502A312F62951070
Coding: 2D2D2D
Passenger's side crash data pedestrian protection:
Subsystem 7 - Part No SW: ----------- HW: 480 402 502 14
Component: PedP_Sensor_P 001 6149
Serial number: 2296502A312F629430D8
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 400 103 14
Component: PedP_Sensor_C 001 6149
Serial number: 23065029912F6294D226
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 BP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 21031408491043
Coding: A418
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 094F9D3909BABC93D8D-805C
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI3
Part No SW: 8V0 920 870 H HW: 8V0 920 870 H
Component: KOMBI H03 2220
Coding: 07A409082B8000080000E800100000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 40D9401D7A003DDBCF3-8014
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 C HW: 5Q0 963 272 C
Component: STH-MQB 006 0069
Coding: A315
ASAM Dataset: EV_AuxilParkiHeateWOS 002014
ROD: EV_AuxilParkiHeateWOS.rod
VCID: 363526C528C4836B65F-8062
1 Fault Found
0375 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[DYSFUNCTION BY UNDERVOLTAGE]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 183
Mileage: 149153 km
Date: 2021.06.03
Time: 14:55:28
Parking heater: operating condition: OFF
71
Coolant temperature of parking heater: 32 °C
Engine running status: not detected
Fuel level: 16 l
Heating performance: 0 W
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001747812
Coding: 030100040B0876005B0002481C0F00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3FDB43E107FE4223B69-806A
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 07 03 2014 C0447417
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 6838892703
1 Fault Found
131659 - Door Control Module - Passenger's Door
U0200 00 [008] - No Communications
[Timeout Knoten 0x4B / 52 - Türsteuergerät Beifahrerseite]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 183
Mileage: 148319 km
Date: 2021.03.19
Time: 12:41:29
Terminal 30 power supply: 14.6 V
Terminal 15: OFF
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 13111302091036
Coding: 00100E205000040000001002
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 42DD4A15740C2FCBD97-8016
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000002132484
Coding: 110000
4 Faults Found
65571 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Türelektronik Beifahrer (J387)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 183
Mileage: 149153 km
Date: 2021.06.03
Time: 13:30:20
65573 - Local Data Bus
U10BA 00 [008] - No Communication
[Türelektronik Beifahrerseite hinten (J389)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 183
Mileage: 148388 km
Date: 2021.03.23
Time: 09:29:55
65593 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 148388 km
Date: 2021.03.23
Time: 09:32:55
589829 - Window Regulator; Rear Driver side
B131F F5 [008] - Supply Voltage too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 149153 km
Date: 2021.06.03
Time: 14:54:34
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DF4519710A34D3C0D-8014
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 13111304080037
Coding: 001006205E00040000001002
Shop #: WSC 06153 128 28888
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000002144787
Coding: 090000
3 Faults Found
65588 - Motor for Window Regulator
B1487 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 3
Fault Frequency: 36
Reset counter: 184
Mileage: 148388 km
Date: 2021.03.23
Time: 09:32:48
65604 - Door Warning Lamp
B1326 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 112
Mileage: 148399 km
Date: 2021.03.28
Time: 15:07:02
589845 - Window Regulator; Front Passenger side
B1320 F5 [008] - Supply Voltage too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 149153 km
Date: 2021.06.03
Time: 14:54:34
Address 55: Headlight Range (J431) Labels:* None
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 0198000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75B7E1C97542C873AC5-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 864 B HW: 8V0 035 864 B
Component: MU-S-N-ER 040 0420
Serial number: A3F02003141024
Coding: 01730301FF00000021110001000A00002F0004440100010006
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 3A2D32F51CDC670B817-806E
Data carrier:
Subsystem 1 - Part No SW: 8V0 919 866 B HW: -----------
Component: ECE 2014 --- 0036
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serial number: AUZ8Z9EY301NQA
Multimedia system control head:
Subsystem 3 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000031011400010203
1 Fault Found
5644 - Control Head for Multimedia System; Left Arrow Button
B1291 FA [009] - Unknown Error Elaboration
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 121
Mileage: 148496 km
Date: 2021.04.18
Time: 14:34:29
Voltage terminal 30: 14.6 V
End----------(Elapsed Time: 01:12, VBatt start/end: 13.3V/13.4V)-----------
