Vcds fault codes assistance
Greece
Hello guys so recently I ve got a vcds and finally done properly coding to my folding mirrors retrofit . BTW I pressed scan and alot of fault codes appeared around 10 I think. I don't even know if it's dangerous or not. I am sure it isn't from me . Some months ago I left my car to various " genius " and probably they got it messed up . The thing I noticed that isn't working on the car a while now is remote closing/opening of windows...
Please someone who knows help me to fix all this ...
I will post the codes below. Thanks
Thursday,03,June,2021,18:03:58:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 21.3.0.0 HEX-V2 CB: 0.4545.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: ---------------------- License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 42 44 52 55 5F
VIN: ------------------------ Mileage: 149172km-92691miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CRBC) Labels: None
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5520
Revision: 83H22---
Coding: 021D001A032401082000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: 7AADF2F55C5CA70BC17-802E
4 Faults Found
7150 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 37 °C
Intake air temperature: 36 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.300 V
Unlearning counter according OBD: 40
17158 - Databus
U1123 00 [032] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 149153 km
Date: 2021.06.03
Time: 14:57:59
Voltage terminal 30: 12.320 V
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: 0.000 m/s²
17262 - Terminal 30
U140A 00 [032] - Open Circuit
[Terminal 30Open circuit]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
Engine control module reset status-Bits 0-7: 0
Limitation: torque: 0.0 Nm
Limitation: accelerator pedal: 0.0 Nm
Cruise Control System (CCS): status-Bits 0-7: 0
Accelerator pedal travel: raw value: 0.00 %
Engine torque: -500.0 Nm
Generator: load signal: 0.00 %
4629 - ECM Power Relay Load Circuit
P068A 00 [032] - Opens Too Early
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Starter control: Interlock- or P/N-signal-Bits 0-7: 0
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0D9 300 040 N HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4305
Revision: 03252204 Serial number: TFK01403011406
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 221DEA95944C0FCBB97-8076
No fault code found.
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 6067400000073C
Coding: 12F162A224270A6C0177060841CB294846245080608294F2026100788608
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod
VCID: 7BA3F7F153669E03DA1-802E
5 Faults Found
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 184
Mileage: 148388 km
Date: 2021.03.23
Time: 00:00:15
16390 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 184
Mileage: 148388 km
Date: 2021.03.23
Time: 00:00:25
32830 - Parking Brake Motors
C10E1 29 [008] - Signal Implausible
[IPB-Actuator: Actuator state UNKNOWN]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 0 km
Date: 2014.03.28
Time: 00:00:18
32928 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[IPB: Supply Voltage below undervoltage threshold]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 184
32948 - Comfort limitation
C10D7 00 [008] - -
[IPB-Miscellaneous: EEPROM data failure]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Date: 2000.00.00
Time: 00:00:00
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000273064
Coding: 03000104002001011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X_008.rod
VCID: 33331FD13BB69643421-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: ED784C17000000000001
5 Faults Found
328964 - Motor for Front Air Distribution Flap
B1091 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 183
Mileage: 148083 km
Date: 2020.10.20
Time: 14:24:32
Voltage terminal 30: 11.7 V
Inside temperature: 19.2 °C
Outside temperature: 19 °C
Front air distribution flap: actual value: 0
Front air distribution flap: actual value: 95.0 %
Air distribution door front - Specified value: 101
329479 - Position Sensor for Fresh/Recirculated Flap Motor
B109B 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 171
Mileage: 148676 km
Date: 2021.05.06
Time: 13:34:43
Voltage terminal 30: 12.9 V
Inside temperature: 39.6 °C
Outside temperature: 30 °C
Fresh air/recirculating air/back pressure door specified value: 859
Actual value for fresh air/recirculation air flow flap: 100.0 %
Actual value for fresh air/recirculation air flow flap: 979
329988 - Motor for Defroster Flap
B1090 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 183
Mileage: 147918 km
Date: 2020.10.18
Time: 10:39:48
Voltage terminal 30: 14.8 V
Inside temperature: 18.2 °C
Outside temperature: 18.5 °C
Defrost door - Specified value: 54
Defroster flap: actual value: 0
Defroster flap: actual value: 0.0 %
1048836 - Blower Output Reduction due to Energy Management
B10CE 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 183
Mileage: 149153 km
Date: 2021.06.03
Time: 13:49:27
Voltage terminal 30: 11.3 V
Blower reduction: No switch-off: no reduction
459020 - Databus
U1121 00 [008] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 183
Mileage: 148319 km
Date: 2021.03.19
Time: 12:41:57
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011407702259
Coding: 04041A46C24120DD43A44004001C07A80400000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_012.rod
Wiper motor control module:
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119
Component: WWS370 140313 041 0580
Serial number: 140314122636
Coding: 0A47F7
Light switch:
Subsystem 2 - Part No SW: 8V0 941 531 J HW: 8V0 941 531 J
Component: E1 - LDS MQB H05 0032
Serial number: 12 12 2013 00000450
Humidity sensor: interior:
Subsystem 3 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20692804
1 Fault Found
549141 - Databus
[TSG_BT_01 Datenbus fehlende Botschaft]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 183
Mileage: 149153 km
Date: 2021.06.03
Time: 13:30:19
Address 10: Park/Steer Assist (J791) Labels:* None
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831408402551
Coding: 0000040011
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_002_VW37.rod
VCID: 382928FD22D0751B773-806C
2 Faults Found
13637120 - Databus
U1123 00 [008] - Received Error Message
[Parkbremse - EPB_01.EPB_Status - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 184
Mileage: 149153 km
Date: 2021.06.03
Time: 14:55:29
13637426 - Databus
[ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 184
Mileage: 148388 km
Date: 2021.03.23
Time: 00:00:15
Address 15: Airbags (J234) Labels:* None
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R05TJ6R
Coding: 98CCC0000C0000005C540000004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4BC367314346EE832A1-801E
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 001 903 14
Component: SideSensor_Df 001 0887
Serial number: 35767000000A85603F0W
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 480 001 903 14
Component: SideSensor_Pf 001 0887
Serial number: 358670000002A5603F0R
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 401 803 14
Component: SideSensor_Dr 001 6149
Serial number: 3516502C5142B1B2D3BC
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 401 803 14
Component: SideSensor_Pr 001 6149
Serial number: 3526502C3142B1B492EB
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 400 602 14
Component: FrontSensor_D 001 6149
Serial number: 3556502A313013F5A26%
Coding: 2D2D2D
Driver's side crash data pedestrian protection:
Subsystem 6 - Part No SW: ----------- HW: 480 402 502 14
Component: PedP_Sensor_D 001 6149
Serial number: 2286502A312F62951070
Coding: 2D2D2D
Passenger's side crash data pedestrian protection:
Subsystem 7 - Part No SW: ----------- HW: 480 402 502 14
Component: PedP_Sensor_P 001 6149
Serial number: 2296502A312F629430D8
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 400 103 14
Component: PedP_Sensor_C 001 6149
Serial number: 23065029912F6294D226
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 BP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 21031408491043
Coding: A418
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 094F9D3909BABC93D8D-805C
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI3
Part No SW: 8V0 920 870 H HW: 8V0 920 870 H
Component: KOMBI H03 2220
Coding: 07A409082B8000080000E800100000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 40D9401D7A003DDBCF3-8014
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 C HW: 5Q0 963 272 C
Component: STH-MQB 006 0069
Coding: A315
ASAM Dataset: EV_AuxilParkiHeateWOS 002014
ROD: EV_AuxilParkiHeateWOS.rod
VCID: 363526C528C4836B65F-8062
1 Fault Found
0375 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[DYSFUNCTION BY UNDERVOLTAGE]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 183
Mileage: 149153 km
Date: 2021.06.03
Time: 14:55:28
Parking heater: operating condition: OFF
71
Coolant temperature of parking heater: 32 °C
Engine running status: not detected
Fuel level: 16 l
Heating performance: 0 W
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001747812
Coding: 030100040B0876005B0002481C0F00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3FDB43E107FE4223B69-806A
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 07 03 2014 C0447417
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 6838892703
1 Fault Found
131659 - Door Control Module - Passenger's Door
U0200 00 [008] - No Communications
[Timeout Knoten 0x4B / 52 - Türsteuergerät Beifahrerseite]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 183
Mileage: 148319 km
Date: 2021.03.19
Time: 12:41:29
Terminal 30 power supply: 14.6 V
Terminal 15: OFF
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 13111302091036
Coding: 00100E205000040000001002
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 42DD4A15740C2FCBD97-8016
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000002132484
Coding: 110000
4 Faults Found
65571 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Türelektronik Beifahrer (J387)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 183
Mileage: 149153 km
Date: 2021.06.03
Time: 13:30:20
65573 - Local Data Bus
U10BA 00 [008] - No Communication
[Türelektronik Beifahrerseite hinten (J389)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 183
Mileage: 148388 km
Date: 2021.03.23
Time: 09:29:55
65593 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 148388 km
Date: 2021.03.23
Time: 09:32:55
589829 - Window Regulator; Rear Driver side
B131F F5 [008] - Supply Voltage too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 149153 km
Date: 2021.06.03
Time: 14:54:34
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DF4519710A34D3C0D-8014
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 13111304080037
Coding: 001006205E00040000001002
Shop #: WSC 06153 128 28888
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000002144787
Coding: 090000
3 Faults Found
65588 - Motor for Window Regulator
B1487 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 3
Fault Frequency: 36
Reset counter: 184
Mileage: 148388 km
Date: 2021.03.23
Time: 09:32:48
65604 - Door Warning Lamp
B1326 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 112
Mileage: 148399 km
Date: 2021.03.28
Time: 15:07:02
589845 - Window Regulator; Front Passenger side
B1320 F5 [008] - Supply Voltage too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 149153 km
Date: 2021.06.03
Time: 14:54:34
Address 55: Headlight Range (J431) Labels:* None
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 0198000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75B7E1C97542C873AC5-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 864 B HW: 8V0 035 864 B
Component: MU-S-N-ER 040 0420
Serial number: A3F02003141024
Coding: 01730301FF00000021110001000A00002F0004440100010006
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 3A2D32F51CDC670B817-806E
Data carrier:
Subsystem 1 - Part No SW: 8V0 919 866 B HW: -----------
Component: ECE 2014 --- 0036
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serial number: AUZ8Z9EY301NQA
Multimedia system control head:
Subsystem 3 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000031011400010203
1 Fault Found
5644 - Control Head for Multimedia System; Left Arrow Button
B1291 FA [009] - Unknown Error Elaboration
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 121
Mileage: 148496 km
Date: 2021.04.18
Time: 14:34:29
Voltage terminal 30: 14.6 V
End----------(Elapsed Time: 01:12, VBatt start/end: 13.3V/13.4V)-----------
I dont even know ... I have changed my rear bumper 3 times the first and last at official dealership the second on one guy i thought he was good but he aint (i left the car 2 weeks to him who knows what he did ?) also before i get the vcds to code myself the mirrors i gave it to a guy and left it for 2 days to him and he couldnt code it ...
Just there are so many faults i am wondering if they are serious ... Can you help me fix at least some of them ?
Another thing i didnt mentioned is that my battery is almost dead
Battery dying could explain the raft of faults. When mine died I was getting all sorts of errors. Maybe replace battery and clear all the codes and see if they come back then work on the ones that come back.
That is what i am thinkink also but i tried already clearing the codes with the key in ingnition and after i restarted the scan the codes reappered . Maybe i should erase them seperately ? I am newbie to this...
Also little bit off topic i guess how i can code the mirrors to close on long press ?
Mines coded to fold on lock not long press. Also activated on the MMI so I can switch off the folding so in winter I don’t get the mirrors frozen in the close position.
can’t remember the coding off the top of my head but the thread on here was great and that’s what I followed
Reactions: Hitmaker22
Thats what i followed as well . Just i dont like it for the mirrors to close on simple lock ( i achieved it likes this) and was wondering if its a way to close only on long press lock .
On topic i think issues are from batterry just i am not sure...
If i change the battery i should do coding as well ? And if yes what kind of coding ?
Sorry for the double post
Update I deleted the codes 1 by one and everything seems fine now except 1 fault that reapers everytime
I think this is related to that windows doesnt close/open via remote anymore :/
Thursday,03,June,2021,19:54:26:16365
www.Ross-Tech.com
VIN: --------------------- License Plate:
VIN: ----------------------- Mileage: 149172km-92691miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Revision: 83H22---
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Coding: 0014
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Coding: 0A47F7
Light switch:
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Coding: 0000040011
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: A418
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Coding: A315
Generator:
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Coding: 110000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Coding: 8103
Coding: 090000
1 Fault Found
B1487 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 149172 km
Date: 2021.06.03
Time: 18:49:29
Data carrier:
End----------(Elapsed Time: 01:15, VBatt start/end: 13.8V/13.8V)-----------
www.Ross-Tech.com
VIN: WAUZZZ8VXEA170088 License Plate:
VIN: WAUZZZ8VXEA170088 Mileage: 149172km-92691miles
Revision: 83H22---
Coding: 0014
Coding: 0A47F7
Light switch:
Coding: 0000040011
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: A418
Coding: A315
Generator:
Coding: 110000
Coding: 8103
Coding: 090000
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 149172 km
Date: 2021.06.03
Time: 18:49:29
Data carrier:
Not sure what that could be. Maybe run basic settings in vcds on that door module and see if it clears. Shouldn’t have anything to do with the mirrors as it’s a rear door module.
Just noticed that at passenger window when I push the button to close it the first time it just doing a noise and the window doesn't close the second time it's working. This happens only at front passenger window. Whatever button I use (driver or front passenger) . Any ideas how could I fix this? It's coding related or ? Thanks. Other than that managed to code the mirrors close on long press the windows open/close with key like it used before ! Also added a new mode (visual optic on screen when parking )
Here is the code I've found on youtube it's awesome !
Go to 10 - Park sterr assist
Then security access 71679
Coding
Byte 2 bit 0 change to 1
