Hi folks, I’m having some trouble with a spec stage 3 clutch (complete clutch kit) in my 2.0tfsi Audi A3 Quattro after trying every form and method of bleeding it up, it has not made any difference, i suspect that the pressure plate could be at fault /or clutch slave I can confirm that the clutch plate was definitely installed the right way round!
The problem is when the clutch pedal is fully depressed there is a rattling noise, sounds a bit like a bad release bearing, when I let off the pedal the noise goes away, but if I try to move off in gear the clutch slips and make the same horrendous noise,
I have also fitted a new clutch master cylinder and a braided clutch line, Before I strip it out can anyone think of anything else to try ?
the spec clutch kit for ref : Application for Audi / S3 / 2006-2012 (SV873F-2 Flywheel: SV87S)
