Also available for FL ;-)
Not worth doing IMO if you don’t then have a map. Big cost for part and to fit. Major ball ache to drop subframe etc. Just spend £600 on a stage 1 map.Can this be run on a stock car and will it make much difference in sound to what I’m running (sports exhaust with secondary decats).
Will you guys be offering these for DNWA/OPF cars (with the bungs for the sensors/probes)? Milltek could really use some competition for the 2018+ RS3's, though I see MRC has already done at least one OPF car with your existing offering, so I assume the sensors can be unplugged or tucked away maybe? Would be good to know. I'd like to go with something other than Milltek when the time comes, and your BCS pipes look superb!![]()
We do not recommend running the downpipe on an unmapped car ;-)Can this be run on a stock car and will it make much difference in sound to what I’m running (sports exhaust with secondary decats).
Thanks the flow ratio we have will allow 750bhp - other brands can't achieve this - causing blowback through the v band flange... We currently supply to OPF specced cars which obviously require the pressure sensors to be mapped out, we therefore do not plumb sensor bosses into the pipe. We could always introduce them if required ;-)
Thanks Nige
The rear sensors can retreat into the space under the plastic undertrays where they emerge from. The forward ones I believe can be unplugged on top of the engine.
