RS Grill finally fitted
Bulldog
Kent
Well I finally got round to fitting my RS grill which I’ve had since October last year. So seeing as most of us are on lockdown I’ve finally had the time & weather to get it fitted. I went for a non Quattro style as mines not Quattro & didn’t want the logo on it.
6843D696 EB62 4AFC BDD4 70A571A355C2
I had to do a few mods to it before fitting as I didn’t want the massive plate holder on it as I’ve got a short 5digit number plate. Plus I wanted a to fit quick release number plate brackets. So I carefully Dremelled out the fixings on the grill which you can see at the side of the number plate. There was 3 of these to remove.
Before
2D392D94 E602 49E4 B04E 8AF0B0CA6432
A61EED69 222A 4B74 817F 02F9A0C5D7F2
After
B9CAB7D6 78DB 44CA B3C4 23A07F3C6C46
Quick release brackets fitted.
FC6A38C0 F2C2 4C5C B0F3 351C9B54EDEB
Plate mounted
66A729AD DB5E 4BFD A2B6 EA593EADDA25
I also managed to get a replacement lower centre blade for the bumper which I had sprayed gloss black to match better with the Maxton splitter.
Lower blade
E6F291A5 F1E6 4299 A20B 843079DF1F62
Painted gloss Black
F7CA2435 0FE9 429E 9066 BDE4C35FAB88
I coated the grill & lower blade with Gtechniq C2V3 to hopefully make cleaning easier.
1D92EB84 DCEB 4D73 AF5C C5C8A2DDD86D
188281A3 0B23 447C AFBD 69CA9651658B
Right so onto the fitting I used this guide from YouTube which helped with this job.
It was quite straightforward do do & you only need a few tools. 10mm socket & t25 & t30 torks bits.
Once the bumper was off you have to paint the aluminium crash bar black to stop it glaring through the new grill.
before
3F57BF8A B659 4BB4 82AB 9C02B73E6AF6
after
6590DC7C B511 4424 BFC7 DE3378F8AE5E
I took the original Audi rings holder which was on the back of the old grill & fitted it to the new grill.
28E027C4 0E71 4B57 8F77 05E950585FB0
I also took this opportunity to bolt the Maxton splitter on properly rather than using the self tappers I’d previously used.
FA448E8A 23F5 418D 844F B5E358472EF6
03508969 BA02 425A 8665 2833851B443D
The parking sensors went straight into the new grill but the clips wasn’t as tight as the oe grill so I put cable ties round them to hold them in place. You can’t see them from the front & it would save having to mess about with them at a later date.
6E83B470 D42E 476E 91CF CFBD026E033C
Onto the finished pics
6B905816 6034 4BC5 8944 EA77B33C6596
EDE2AC54 42E9 4BF3 AC4C 169DDF97020E
C6E14DCC BCB1 45E0 9C77 3202396A9AFB
Thanks for reading & hope other find this helpful when they do there’s.
Reactions: Nathan89, L111 FAD, blackwood and 15 others
Cheers @CHEZ hopefully it does. I’ll be breaking out the machine polisher over the coming weeks too.
haha, i need to get mine sorted out now.... It's been sat in the garage for a while...
Reactions: Bulldog
How many screws did you have left over? Finished mine today and I have 2 screws left :whistle2::yahoo:
Reactions: Badger-a-s, Bulldog and CHEZ
@J10NMM the bigger one looks like it’s from the arch liner & the smaller one is maybe from under neath the bumper which goes to the under tray maybe
Bulldog, I see you used that video to help you get the bumper off. It's a great vid but I struggle to find that 3rd bolt under the wheel arch liners.
First 2 are obvious, but that 3rd one where you have to get an extended socket through that hole... I just can't find? I get my fingers in there and all I get is steel frame.
I might add that I drive a C7 Allroad, but I wouldn't have thought the bolt locations are any different. I attach a pic for ref...
P. S. You might remember me, I'm that Chinese fella that took your roof bars off you a while back
@Duck A4 that 3rd bolt is under the headlight if you put a torch there you can see the bolt through the hole. Yeah I remember you fella how you finding the C7 platform ?
Hmm, I think I'll have to have another check. I only turned my wheels full lock and didn't remove them so maybe the angle wasn't right.
Mate, the A4 was always a touch too small but I went for it because it looked the part and ultimately better than my Q5.
But this 3.0 C7 is a beast in comparison, and with the leg room to boot! Always fancied an allroad too so the decision was pretty easy.
Almost went for a 313bhp BiTdi, but ended up with the 272bhp... And got it tuned to 320bhp. Miss that noise though!
Reactions: Antonyb and Bulldog
@Duck A4 just use a long extension bar & you’ll find it. I nearly went for a B9 Avant before I got the C7 but couldn’t find one with a decent spec & my C7 has got an amazing spec so was a no brainer.
drop @J10NMM a message as he might want to sell his black edition grill.
Reactions: Duck C7 allroad
Yeah I remember you showing me all the bells and whistles! It really doesn't want for anything that car... Except maybe a couple of chrome exhaust trim parts!
Thanks for the heads up about the grille. I love my allroad, but it doesn't have the B8.5 black edition looks so I'm trying to reclaim that.
Only got it in late December and so far I've wrapped the interior trim in gloss black, tinted windows and wrapped the surrounds, changed the chrome roof rails to black, changed the wheels and painted the calipers... Lock down has some unexpected benefits..!
Reactions: Bulldog
@Duck A4 I’ve fitted tailpipe trims already.
86381224 198F 439C 8C48 34018D550D1E
Reactions: blackwood, DonkeyIce and Duck C7 allroad
Bulldog, did those quick release plate holders come with the new, shorter plate or was it a seperate purchase?
@Duck A4 to be fair the newer design look better as they look like they’ll spread the load of the plate better as mine only go through 1 hole in the mesh. I’d get them as there’s not much else out there.
Interesting. Well at least I can remove the existing plate holder easily enough whilst my replacement grille is in situ
These pictures are from the seller, but they don't really do it justice, it's in mint condition.
Still debating whether I want a chrome badge instead. Although I have a black boot emblem, I like the idea that the chrome pops on a black grille.
I’d go for chrome badge on the front as I think a black badge makes it look like someone’s nicked you badge lol. I’ve debating weather to put a black badge on the rear of mine for ages but can’t make my mind up !!
Ha ha! You might be right! :)
Might need 4 of them!!
Although I am seriously thinking of tearing off any sticky pads and using a flexible epoxy of some kind.
I’ve got them on mine with no issues at all even at speed they haven’t moved & they’re a nice tight sturdy fit.
Just got my new sensors today and although they clip in correctly on the rear, the front protrudes by about 5mm.
I know neither the grille or sensors are oem but apart from it not being neat, does anyone think that this'll be a problem in day to day use?
I wouldn’t have thought it would be an issue can you not pull them back a bit & use a cable tie similar to how I did ?
I did think that, but then I'd have to take out the retaining 'tooth' on each side of the sensor retainer. Maybe with a dremmel or something.
Without taking those off, the sensor just pops forward becuase it's a fairly snug fit.
That’s probably why as most things non oe never fit right. If you are going to use them before you fit try your original sensors first to see how they fit. On mine I’m 99% certain they fit flush.
That's a good plan but I'd need to paint them black... And I'm not sure if the paint would affect the sensor?
Reactions: Bulldog
