I replenished the resin in mine the other, without the tube being in place however I might invest in the refill kit.
Water tests at 0ppm from 148...
I have similar input reading @OCDaveS3, so am contemplating daisy chaining a chlorinator as @45bvtc has done to excellent effect.Useful tips which I shall use on my Vyair - starting to get water marks after 5 months usage with weekly wash (sometimes more!). Reading at 17ppm against input reading of 250ppm! Now to find a good source of resin...........!
Again, full credit to jaysrs4, Nev; see: https://www.audi-sport.net/xf/threads/deionized-water-rinse.368598/page-4
jaysrs4 said: "I have the same set up here. However I'd recommend also fitting a 'de-chlorinator' before the deionizer. Reason being is that I did a load of research before investing in this kit and it appears that chlorine in the water massively degrades the resin. You'll get far more for your money if you fit one pre-line."
I just followed his advice and it does seem to work as I've had little or no degradation in ppm measurements from the Raceglaze soto jaysrs4.
The de-chlorinator I have is still showing on Amazon @ £29.99
Thanks for sharing this @X3man and @45bvtc - might have to go down this route myself. I’m measuring close to 450ppm at input , and only got 3 months out of my last tank of resin. Which is putting me off using my Raceglaze as it starts to become an expensive luxury. Will check this out - thanks again.
My set-up is: mains tap water (tee-fitting above the hot and cold water taps) to de-chlorinator to Raceglaze and then Raceglaze via dedicated hose to car rinse and/or bucket if cleaning windows, etc:
Ouch, that is a HIGH reading. I am gonna get this setup too, been meaning to for sometime tbh
Nice one pal - can the dechlorinator be used in-line with a pressure washer and the Raceglaze i.e. tap -> short hose -> dechlorinator -> short hose -> Raceglaze -> short hose -> pressure washer?
Or do you have go dechlorinator -> Raceglaze -> garden hose gun?
water oozes out of my hoze in gloopy lumps, lol.
There’s definitely an innuendo in that comment .
