Folding mirrors retrofit
Hello
Just to make it clear what I am asking, has anyone tried this type of switch in an 8V?
Folding mirror ebay 8p  switch
To my mind the only thing that's missing is the position for 'off' and I don't think you need that anyway, unless I am missing something??
IS the O position 'auto'
If this works there will be no need to change the armrest along with all the disturbance that will cause.
Hello
That won’t work as on the 8v the symbols are on the armrest trim not the switch and there’s no holes for those symbols to poke through.
Don’t think that switch is the same shape either. Will confirm later with the bits I have in my garage.
Hi thanks for the input - on my car a 2017 8V S3 saloon the holes are definitely in the armrest and there is a 'mask' which goes in-between the switch and the arm rest with the symbols on them, there are different masks, I have even considered adding the extra holes which also would save swapping out the armrest, (but leave an extra 'blank' hole)
This raises another question - The backlighting for the symbols is inside the switch, does anyone know what the difference in part code is between a switch with red led backlighting for the symbols is and a switch with white backlighting behind the symbols is? or is the backlighting all white and it's the mask colour which changes?
16160063955771616006650516
The symbols are in a mask This is mine
View attachment 233382View attachment 233383
These are the part numbers for my 18 s3 sport back, not sure if they are the same as saloon.
8v0959565n switch with white backlighting
8v4959522b armrest trim with holes for the lighting from the switch.
If I remember right it was about £50-60 for the 2 delivered from Crewe Audi on here.
Reactions: Potterswheel
Great @AlS3BE thanks for looking, glad to see we are now singing off the same sheet.
There seem to be so many part N°'s for the same switch, weird
I have asked Tom at Crewe Audi for a price today but didn't have the N°'s, for that price it's not worth messing about with, in fact I think they want more second hand!!!
Yes I thought they were, this one says it is red:-
£58 for a used one !!
Definitely didn’t pay that much, remember switch and trim was pretty cheap, trim might have been something like £15-20 so the new switch is like £25-30. total was around £400 for 2 mirrors without caps, switch and trim. All brand new. Luckily didn’t need mirror modules as some have as thats another couple of hundred quid.
Maybe exchange rates have changed since brexit and everything is more expensive.
When you say "switch and trim" do you mean the mask which fits around the switch or the complete arm rest? and did you have much fun changing the armrest
Armrest trim on the door card. I’ve not fitted the trim yet, didn’t have the right tools at the time so just put the switch in. The symbols are wrong but the switch fits in place. Will get round to it hopefully next week now the kids are back at school.
Right, so the armrest is called the trim? so you have the new switch under the existing armrest like I was suggesting?
Think the armrest trim piece is officially called the bezel from Audi. Nothing like trying to confuse folk ordering parts.
Will have a look at the boxes in the garage next time I’m in there.
I have just placed my order with Crewe Audi for the following Items:-
8V0959565n switch with white backlighting £40.00
8V4959522b switch trim/grab handle £20.00
switch mask which I don't yet have the part N° for £4.50
There are charlatans charging more than this on ebay for second hand rubbish which they have mauled off a scrap/stolen car and they don't understand what they are selling, lesson learned here .................... I can do without the hassle
Did this swap today. Took like 2 hours to do the drivers side and about 20 minutes to do the other lol. Took me a minute to notice the cable wrapped behind the channel for the window (DUH)
To anyone asking about the armrest trim removal : you need to remove the t15 torx screws. There are also a few spots that are melted plastic that are holding it together. If you pull hard enough they will snap off. Or you could be smart and heat them up. Either way it doesnt affect how secure the arm is.
I did my folding mirrors last week, couple of things I found out which may help others and add to the accumulated knowledge :-
Firstly I used a dent 'sucker' to remove the glass, cost £3.00 and removed the glass a treat, without risking breaking the £40.00 + glass.
Mirror sucker
Secondly, I used a piece of cable attached to the old mirror connector and 'pulled it in' to the inside of thedoor when removing the old mirror, I simply attached the new connector to this cable and pulled it round the window track when installing the new mirror the cable had to follow the correct route then, all that was left then was to replace the two 'fir trees' and job was a good un.
Old connector removal 2 Inside the door
orange cable attached to old connector inside the door, cable routing
I removed the round plastic welded fixings with an 8mm spot weld removal drill and then replaced each one with spare self tappers previously swapped from inside the arch liners by drilling a 3mm hole in the center of each 'post' and then screwing in the 'big head' screws, this made a good job of fixing the arm rest back in place. I cut the 'flap fixing off with a small disk in a Dremmel and rewelded it with a soldering iron,. You do wonder why Audi fixed it in place with mixed fixings and did not either use all plastic welds or all screws, weird! Perhaps made in one place (country) and assembled in another.
Reactions: AlS3BE
Only thing I haven’t gotten to work is the mmi menu. The mirrors fold in on lock and unfold when starting the car. The switch works as well.
perhaps something is done differently in VCDS in my 2017.
I feel like I scored on these used mirrors. Going from heated manual fold to heated land auto dimming power folding. The glass price for these is astronomical.
I guess I was just looking in the wrong spot. Hadn’t considered it would be under locking.
Ever wondered what was inside a door ECU??
Door ecu inside
lots going on in there, this was a standard ECU that was bundled with my power fold mirrors, fortunately my existing ones were fine as this one had been butchered out of the car!!!!!! there wern't enough pins for the N° of cables in the mirror plugs and I doubt that the right software (firmware) is loaded.
nice ornament though!!! I always think PCB's look like small cities.
I am still tidying up after a busy few weeks!!
Reactions: AlS3BE
Evening
So, with the help of forum members I retrofitted powers folding mirrors to my FL 2019 S3 Sportback. I would say it was successful, but while everything seems to be working OK, when I run a fault code scan with VCDS, I get the following errors (they will not clear). Is this normal after the retrofit? Also, when you unlock the car should the mirrors open, or only when the ignition is turned on? Re the errors, I'm not convinced everything is coded correctly, as on the facelift the selections seemed to differ! Is there any way of checking the coding? Thanks very much.
52 - Door Elect, Pass
524387 - Databus
U1121 00 [009] - Missing Message
19 - CAN
66304 - Databus
U1124 00[009] - Additional Installations Detected
No faults on mine.
mine is set to fold on lock with setting in MMI.
unfold only happens when ignition is on.
will have a look at my coding on mine next time I have a chance
Thanks so much.
Scan follows:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 08 09 10 15 17 19 22 29 39 42 44 4B 52 5F A9 BB BC
D6 D7
VIN: WAUZZZ8V7KA044038 Mileage: 25489km-15838miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DNUE) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 N HW: 06K 907 425 J
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 0A2540122426010B2004
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TFS0208V0906259N 001002
ROD: EV_ECM20TFS0208V0906259N.rod
VCID: 4BC3675A134238732A1-801E
No fault code found.
Readiness: 1010 0001
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0GC 300 014 B HW: 0GC 927 711 H
Component: GSG DQ381 H06 2404
Revision: 00H06V07
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ381061 001
ROD: EV_TCMDQ381061_VW37.rod
VCID: 2411ECE6DE5CD70BCBB-8070
No subsystems:
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 8V0 614 517 D HW: 8V0 614 517 C
Component: ESC H25 0640
Revision: 00000000 Serial number: 63008000000129
Coding: 329C938D549D23AD8B910B674099694CC92AC4D1D0029677024150748208420000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037008
ROD: EV_Brake1UDSContiMK100IPB_037_AU37.rod
VCID: 3A2D329E4CD8B1FB817-806E
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 AF HW: 8V0 820 043 AF
Component: AC Automat H03 0150
Revision: 20003000 Serial number: 00000001691030
Coding: 03100004000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
ROD: EV_AirCondiFrontVaAU37X_008.rod
VCID: 76B5E6AE3840159BA5F-8022
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 40E01B5900PAG0MUFU03
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 DC HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H38 0273
Serial number: 00001831201487
Coding: 000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019.rod
VCID: 7CA1F486066C4FCBD3B-8028
Wiper motor control module:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 181016 043 0580
Serial number: 181026082102
Coding: 0A47F7
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21711309X81A955547A0
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 05 09 2018 20000251
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY1828017QR
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000030690753
Steering Column Switch:
Subsystem 6 - Part No SW: 82A 953 521 A HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000017111808490971
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 C HW: 5QA 919 283
Component: PDC 4 KanalH07 0050
Serial number: 000308419318314
Coding: 0600040011
ASAM Dataset: EV_EPHVA14AU3700000 009037
ROD: EV_EPHVA14AU3700000_009_AU37.rod
VCID: 4ACD625E1C38217B117-801E
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 BT HW: 5Q0 959 655 BT
Component: AirbagVW21 006 0403
Serial number: 003FNR4TA9D4
Coding: 98CCC0000C0000005C5400CA00C8000000C5
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 1373BF3A0BF2A0B3221-8046
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 001 011 18
Component: SideSensor_Df 001 0887
Serial number: 35700000000FC764A53Y
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 480 001 011 18
Component: SideSensor_Pf 001 0887
Serial number: 358000000003D764A53O
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 401 511 18
Component: SideSensor_Dr 003 6149
Serial number: 3510001AF2C62405B753
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 401 511 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001AF2C62405B2C6
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 402 510 18
Component: FrontSensor_D 004 6149
Serial number: 3550001142B7B5D3338%
Coding: 2D2D2D
Driver's side crash data pedestrian protection:
Subsystem 6 - Part No SW: ----------- HW: 480 400 511 18
Component: PedP_Sensor_D 003 6149
Serial number: 2280001B32DA6D94D72K
Coding: 2D2D2D
Passenger's side crash data pedestrian protection:
Subsystem 7 - Part No SW: ----------- HW: 480 400 511 18
Component: PedP_Sensor_P 003 6149
Serial number: 2290001B32DA6D94481C
Coding: 2D2D2D
Driver's side crash data pedestrian protection 2:
Subsystem 8 - Part No SW: ----------- HW: 480 000 911 18
Component: PedPSensor_D2 001 0887
Serial number: I0M000000008E3C8C53J
Coding: 2D2D2D
Passenger's side crash data pedestrian protection 2:
Subsystem 9 - Part No SW: ----------- HW: 480 000 911 18
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000502EC163+
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 790 B HW: 8V0 920 790 B
Component: FBenRDW H19 0108
Coding: 24AD08422B8006000101E8001000000000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001032
ROD: EV_DashBoardFPKAU37X.rod
VCID: 3B23379A43E288F39A1-806E
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 442 4366
Revision: -------- Serial number: 0008729978
Coding: 030100043F085A005B00826A3C0B00000001010000000000000000000000
ASAM Dataset: EV_GatewNF 013025
ROD: EV_GatewNF_AU37.rod
VCID: 6E85CECE40102D5B6DF-803A
Generator:
Component: 0-00-00-00-00
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20181026195239 22581
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75886002001811033A3D
1 Fault Found:
66304 - Databus
U1124 00 [009] - Additional Installations Detected
[Mehrverbau CAN]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 25489 km
Date: 2021.07.18
Time: 20:23:32
Terminal 30 power supply: 12.5 V
Terminal 15: On
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H55 7762
Serial number: HA1-00011.10.18
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X.rod
VCID: 4DC76942ED563643345-8018
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 D HW: 8S0 907 397 D
Component: LCM_MQB H07 0022
ASAM Dataset: EV_LCMLeftCONTIAU426 001009
ROD: EV_LCMLeftCONTIAU426_VW41.rod
VCID: 42DD4A7E2408F93BD97-8016
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
ASAM Dataset: EV_LCMRightCONTIAU426 001009
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007RK201659
Coding: 001C8A205001000000001002
ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001010
ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
VCID: 44D14C663E1CF70BEBB-8010
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 811F0000
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C21348646EC8FCB93B-8068
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 11111810802351
Coding: 000000050900147600102B03020000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW41.rod
VCID: 353721A265C65E836C5-8060
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007RK123401
Coding: 001C82205E01000000001002
ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001010
ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
VCID: 43D34F7A3B12F033D21-8016
1 Fault Found:
524387 - Databus
[Message Mem_FS_01 missing]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 156
Mileage: 25489 km
Date: 2021.07.18
Time: 20:24:04
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 8V1 035 035 C HW: 8V1 035 035 C
Component: MU-P-LND-EU 055 1326
Serial number: A698K0JS029767
Coding: 01735301FF0A000011111101000A00312F0027E701700100DE
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
VCID: 323D1ABE94A849BB497-8066
Data carrier:
Subsystem 1 - Part No SW: V03 959 802 DD HW: -----------
Component: ECE 2018/2019 --- 0169
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9J1Y0EQMQ
Multimedia system control head:
Subsystem 3 - Part No SW: 8V0 919 614 BJ HW: 8V0 919 614 BJ
Component: ControlUnit_H H85 0855
Serial number: ALJAL109071800050279
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1017
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 181024201519
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 3E253E8E50F09DDBBDF-806A
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 8W1 959 595 D HW: 8W1 959 595 D
Component: TSG HFS003 0187
Serial number: YE007RK60042B
Coding: 000C82204001000000001002
ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001010
ROD: EV_DCU2RearDriveMAXHCONT_VW41.rod
VCID: 4EC56E4EE0500D5B4DF-801A
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS003 0187
Serial number: YE007RK51233C
ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001010
ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
ROD: EV_LEDModLeftMELCOAU736_VW37.rod
VCID: 176BCB2A1F0A8C935E9-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0008
ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----------(Elapsed Time: 01:28, VBatt start/end: 12.8V/12.8V)-----------
I do not recall having this option
42 and 52 > Check Byte 6 > Bit 0-3 should be variant 5.
Nothing said Variant 5
001C82205E01000000001002 your scan
005D8220DE01040000001002 mine
My 52 coding from an old scan. It’s slightly different to yours
Some would be stuff like door lights, b&o, puddle lights etc but there’s one that’s power folding mirror.
Great, thanks.
Any suggestions as to how to approach this?
It would be a huge help if you could check what you have selected in 52 - byte 6 please, as I think you have a facelift too?
Really appreciate the time you and Alex are spending trying to help.
I might be barking up the wrong tree, but perhaps this is the issue? This is what I have - I’ve not changed it.
Great, thanks.
My coding is above. Byte 6 is 04.
I think it’s your byte 04 bit 5 is wrong.
Would leave that alone just now. Your 42 is error free. It’s your 52 that’s got error
Had a quick google. Byte 04 has a bit called powered mirrors or something like that. So it’s just a case of using vcds and selecting the correct bit then pick from drop down boxes. Depending on what you pick the value will change.
Thanks.
So, 52, Long Coding, Byte 4, then what do I select? Sorry, for the silly question.
Thanks.
Exit then ‘do it’.
can’t really think what term they used. Auto pilot when I’m using vcds.
Thanks, sorry, I didn’t word it well! Once I’m in byte 4, what so I change? Cheers
You should have drop downs or tick boxes. Vcds should have labels on most of the bits so it’s a case of selecting the correct one. One of the selection is powered mirrors.
there’s a way to use long coding and just typing it in as well.
its been a while since I’ve had to used vcds cause I have the old hex can cable which doesn’t support the newer cars. Have to borrow my mates newer cable or use obd11 now and not really had to do anything for ages.
Thanks again. I’ll take a fresh look tomorrow and report back. Cheers
Right, still no clearer I'm afraid.
I have made some changes, as the long code is similar to yours, but still the same error!
What other things have you changed in vcds in other modules other than the door ones?
Right, first of all thanks for your assistance!
To update, I reached out to Alex at VAG Car Coding (member who supports these forums), who very kindly connected remotely, and methodically reviewed everything and essentially found a selection I had made that wasn't necessary - hence message error. Alex checked everything for me, and even addressed something else that was bugging me!
I cannot recommend Alex enough, so if you need anything looked at professionally, he is your man!
And to top it off, he would not accept payment. Only after twisting his arm would he agree to choose a charity for me to send a donation to.
So, thanks very much to both members.
Until next time!
Reactions: DJAlix and AlS3BE
Until next time!
Alex is great to deal with. Another recommendation from me. :icon thumright:
so own up, what button/check box or procedure did you do that you shouldn’t have :wink:
Reactions: DJAlix
Something to do with mirror dip I think. Alex can hopefully confirm!?
