Few codes popped up
mattyboy199
UK
Already know about the headlight issues but they sit ok now, but horn and key ? What's up ?
Address 17: Instruments
Labels: BL0-920-xxx-17. Ibl
Part No: 8LO 920 980 R
Component: KOMBI+WEGFAHRS. VDO DO9
Coding: 01444
Shop WSC 01089
VCID 428A72944EBFDO51BF-515A
AUZ7 DA200232g
WAUZZ78L721009045
1 Fault Found.
01176- Key
07-10-Signal too Low Intermittent
Address 35. Centr. Locks
Labels: BD0-862-257 lb!
Part No: 8DO 862 257 E
Component CV.Pump, Alarm, RC D17
Coding: 15178
Shop WSC 01236
VCID: 2F6C2B2OED1D4D3940-4F56
1 Fault Found:
01134-Alarm Horn (H12)
7.00Internal Supply Voltage
Address 55: Headlight Range
Labels 4B0-907-337-AUT lb
Part No: 4B0 907 357
Component LEUCHTWEITEREGLER DO04
Coding: 00010
Shop # WSC 01236_
CID 65C08908FF61C7697A51D0
2 Faults Found:
01539- Headlights Not Adjusted
35-00
00774- Level Control System Sensor, Rear Left (G75)
31-00- Open or Short to Ground
Top one of guess is low key battery.
Second is the alarm in the boot below the sub has packed up. Usually the batteries leak, lots of info on here about them.
The third is to do with the sensor on the passenger side rear tie arm, there will be a metal sensor, best to check it out.
Reactions: andrew_wright
