Isn't life too short to mess about like that?Does anyone use a leaf blower or similar to get excess water off those tricky to get to places after it Been washed? Interested as to which one to get. Cheap and easy or a little more pricey.
Unlike some others I can appreciate where you're coming from on this.Does anyone use a leaf blower or similar to get excess water off those tricky to get to places after it Been washed?
What I didn't know is that you can push the mirrors "the wrong way" (opposite way of how folding them in).This car I find is much better....its only really around the mirrors and bottom of the doors that drip, so I can live with that.
Your gonna have to elaborate mate?? Threads about getting excess water from tight spots.What do you do when it rains, never go out?
There's a difference though! When it rains the entire car is wet... not just in a few places (mirrors, fuel cap, door handles)What do you do when it rains, never go out?
I will mate.Your gonna have to elaborate mate?? Threads about getting excess water from tight spots.
There is a difference but the problem/issue is still the same.....water in tight spots.....hence my question.There's a difference though! When it rains the entire car is wet... not just in a few places (mirrors, fuel cap, door handles)
problem/issue is different because as already stated the whole car is wet.There is a difference but the problem/issue is still the same.....water in tight spots.....hence my question.
Because when it rains I'm not washing it. I only wash it when it's dry. Hence the need to dry it. So it looks like this.I will mate.
It’s obvious what the thread is about, so my question is what do you do when it rains? What’s the difference between washing your car and worrying about water in tight spots or it raining and worrying about water in tight spots? Surely the problem/issue is exactly the same?
Errrrrr, ok.problem/issue is different because as already stated the whole car is wet.
But it will still look like that without the need to use a hairdryer on the tight spots....which nobody can see anyway.Because when it rains I'm not washing it. I only wash it when it's dry. Hence the need to dry it. So it looks like this.
Its ok....we have OCD issues which can be hard to understand.Errrrrr, ok.
Clearly I’m lost so this is where I bow out.
It's ok mate. I just find that I can do my best to dry the car within an inch of it life and after a couple of miles I have water marks strewn down the side of the car. Also it's a pain cleaning the water spots from all the honeycomb grill spaces.I wasn’t even trying to be funny, I genuinely don’t get it. When I wash my car I do a thorough job BUT I don’t worry or even think about water in tight spots, but it still looks amazing.
I guess we all have different standards.
The water drips though and runs down the body, door panels etc.. So need to get the water out of the tight spots.I wasn’t even trying to be funny, I genuinely don’t get it. When I wash my car I do a thorough job BUT I don’t worry or even think about water in tight spots, but it still looks amazing.
Fair comment.It's ok mate. I just find that I can do my best to dry the car within an inch of it life and after a couple of miles I have water marks strewn down the side of the car. Also it's a pain cleaning the water spots from all the honeycomb grill spaces.
I get it, maybe my standards need raising a bit.The water drips though and runs down the body, door panels etc.. So need to get the water out of the tight spots.
If it didn't drip down and cause water marks. Then couldn't care less. But when it's all dry and clean and you then have water marks in a few places it just looks bad.
I use a water filter for the final rinse.
Does a good job and you just leave it to dry naturally without having to put a towel to the bodywork.
All contributes to less swirls!
Happy birthday @MattSedg - treat yourselfI use a air line when I can get my car near it at our workshop. Very handy.
I've considered a cordless Makita leaf blower before, might do now my car is properly coated
It's an aqua gleam 30ppm, you can get a 0ppm version but it's unnecessary as the difference in finish is negligible and it won't last as long.What water filter do you use? Didn't even knew something like that existed but I know I need it in my life! (Please don't tell it's one of those big expensive ones that you have to install inside the house)
The missus picked one of these up for me:
EDIT: Can't seem to link to Amazon for some reason. Anyway it's a `MotoDryer - Vehicle Dryer and Duster for Detailing` on Amazon.
Been using it for a while now, does the trick. I give the car a quick whip around with it to get some of the annoying bits out. Wing mirrors, door handles, wheel nuts, etc.
For those wondering, the reason we (I anyway) want to get rid of them is because the moment you drive the car, you'll get water streaks on the panels near the places i've mentioned. It makes the car look a bit crappy and after you've spent the time to wash it, it may as well at least look spotless for a bit.
I can vouch for one of these. Started with aquagleam, but it only lasted 10-12 rinses. Have used Raceglaze for more than that, and not needed to change resinThat has a finite life so would this be better value for money?
http://www.raceglaze.co.uk/car-care...er-filters/400-litre-0ppm-car-washing-filter/
spot on, good links
We have terrible hard water where I am. If I do not hit the lines after the car is dry, the calcium will solidify on the paint and cannot be removed after sitting in the sun except with clay and polish. Really stinks. This is even with water treatment system as mentioned above.
May sound like additional work for some, but to keep the paint and clear coat in good shape, I have to hit the pooling water spots with air post rinse.
As mentioned in other reply, I had a aquagleam 0ppm, and after 10-12 rinses, when water was tested was showing 122ppm (my water is 225+ ppm).It's an aqua gleam 30ppm, you can get a 0ppm version but it's unnecessary as the difference in finish is negligible and it won't last as long.
http://www.polishedbliss.co.uk/acatalog/aqua-gleam-350-mm-de-ionising-water-filters.html
Sent from my Note 8 using Tapatalk
you won't be disappointed @Lehn, and will be amazed at how much water run-off you get with 0ppm vs. normal tap waterThis is just great! Thanks for the info guys, think I'm going for the Raceglaze version.
