Ahh right, yeah with a touch of red in other places will tie together.
I see where your going
Looks really good @Buxton2901 Nice subtle ModAnother comparison
Not wanting tobut I am keen to get spacers for my 19" Q5 wheels.
Any recommendations? Maybe I should start my own thread on it
Yes the badge is removable as I have removed and coloured mine in red, and yes I got my money back immediately from the eBay selling when I sent them a photo of the letter from UK border control!Is the quattro badge on front grille removable too you reckon? Im fancying ordering one. When the first grill got stopped at customs did you get money back? Thanks for help
Computer shows 33mpg where as usually it's at 30 but will see this week if I actually get more miles from the fuel used
I have 20” 9J rs6 Rep wheels on ET35 and stock 255/35/20 tyre which poke out 16.4mm wider than the stock 8.5j 20” ET45s on the same tyres but I get no rub whatsoever which Is strange after reading your info,not disagreeing but just putting the info out there.Im hoping some rs6 21” Oem will fit,any ideas?i meant to reply to this last week regarding the width of spacers and what you can get away with. 10mm on the front will rub occasionally. 15mm will rub a lot. Even with my car set in comfort mode which I have set as standard ride height the front will rub with some lock on and turning into an incline. 15's on the rear is about the most you can get to. When I put my car in "show mode" and the wheels are tucked up in the arches there is no space on the rears with 15mm spacers. Definitely not enough to get an extra 5mm width. Although I would assume it would only be an issue when you had a heavy load in the rear.
Have you tried some t cut/meguiars scratch x or similar on the badge marks? I debadged my B8 this weekend and had similar marks but scratch x sorted them out. Lovely motor by the way would love to upgrade to one of these at some point! Where did you order your plates from?Little more progress.
Black rings now fitted..
Annoying thing is you can still see where A6 and TDI badges were, I my when the sun hits it thoughView attachment 154284
Sent from my SM-G930F using Tapatalk
Thanks mate I will give that a go. Can onto notice it I direct sunlightHave you tried some t cut/meguiars scratch x or similar on the badge marks? I debadged my B8 this weekend and had similar marks but scratch x sorted them out. Lovely motor by the way would love to upgrade to one of these at some point! Where did you order your plates from?
Hi mateI have a 'version' of VCDS but it won't work on my 16 plate, so I'll have to upgrade to enable that feature.
Think I've seen the shift lights on a video somewhere though and it does look awesome! Alarm chirp & needle sweep are on the to do list too.
Hi mate
Can the alarm chirp and sweeping needles be activated on a 2014 C7 bitdi?
If so where do I look for the adjustment on VCDS?
Ah ok.I wish I could help, but I no longer have VCDS, so I can’t even go into it to look at the pathway to these mods. I want to enable these too, but I’ll have to ask a member on here to do mine for me.
One thing I remember you can enable on a 14 plate that I can’t, is enabling Video In Motion, so if you wanted to, you could play DVD’s while driving (for your passenger obviously, not yourself.
I’ve got a licensed VCDS usb hex can lead so I’m hoping someone could comment on here on how to do various tweeks.I don't have vcds but have enabled these using carista. You can buy a dongle from eBay for about a fiver then pay for a week access pass I think for carista pro which is about 5.99 or 6.99 from memory and can make a lot of different mods and also scan for obd faults
Ah ok.
Looks like I will be asking members to.
Can you remember how do the video in motion mod?
Apparently the centre console trim is a ball ache to get off so that's the last peice to do lol
Yeah from what I have read the whole centre console has to come out. Arm rest the full lot. Couple of hours work
