A3 8P bonnet won’t open
Will_S
DEREHAM, NORFOLK
I thought I would do a write up on a problem I had the day after buying my car. I pulled the bonnet release under the dash and heard a loud noise and the tension in the release went. The cable that runs though is in fact in two seperate sections connected together by a piece of plasic, Turns out in my case the plastic connector had snapped. I had a look and had some theories about how to get into it but thought I would go to audi for some advice. They told me that in the past they have simply cut the bonnet off and replaced it, £2500, no thanks.
This is how I got the bonnet open without touching the cable and should work regardless of what has gone wrong in the system. My method was to remove the locking mechanism from the car and keep it attached to the bonnet.
Step 1
I started by getting a gap between the grill and bonnet, this was done by very carfully and progressively pushing wooden wedges into the gap, this pushed the grill down by about 5-10mm. I also made a little light out of a interior bulb, heatshrink and a legth of wire to be able to see inside as a normal torch and head torch was difficult to get the beam in the right place.
Step 2
The lock is held into to the body by 3 bolts, once these are taken out the lock will just lift out with the bonnet.
To get to the first two most frontal bolts you have to remove some material from the secondary catch as this sits infront of it. To do this I got a flat wood drill bit and covered the shaft in foam to stop it rubbing on the bonnet, slide it in and drilled in to the handle where the bolts sit behind. I then got a wood chisel and cut the matrerial between top and bottom of the holes and the top and bottom of the catch and removed the outer bits of material.
Step 3
You then undo the 2 bolts and pull them all the way out. Lift the bonnet slightly and this gives you access to the 3rd bolt. Undo that and the unit lifts out. Hey presto. Careful not to lift the bonnet too high as the cable and electrical wire for the sensor inside may still be attached.
Reactions: Simon50s, abmat, aqibi2000 and 1 other person
Thanks Will you have saved my bacon (almost) !
Unfortunately I destroyed the plastic lift catch and don't know how to get around this, any ideas ?
Im not bothered about the mess I've made to the car, its a piece of sh1t (never buying Audi or VW again) and Im sick of fixing it all the time! I have to run it into the ground and need to get it through the mot which expires in 1 week
IMG 7831
Untitled
IMG 7834
Reactions: Al001
Would be a pain to open the bonnet on any car if the cable broke at the bonnet end.
Just had to do this on my 8P. What a lovely job. Posting here what I did in case anyone else is searching Google.
Oh how I laughed as I finally freed the bonnet, it jumped up, tugged the sensor cable and crashed back down on my fingers.
Thanks for the ideas and help, appreciate you posting photos!
The cable had come off my bonnet release completely, so I couldn't go in through the driver's side wheel arch and yank on the cable. There is no access from underneath to pull/push the release with just the undertray off, in my opinion.
I got a couple of air wedges (£10 from Amazon) and a hacksaw handle (£12 from Amazon).
I removed the grill surround for better access... pretty scary but I literally just used my fingers to find a place to start (pushing it up at the top for me) then it came off without damage.
I could get the saw blade in there horizontally so I cut the bonnet release hinge in two places so I could push out the hinge pin with a long screwdriver and move the plastic release catch to each side to undo the bolts. I've seen some people just get in there with a recip saw and zip through the whole hinge but I didn't fancy that.
It's one of those jobs that if you've done it before it would take a quarter of the time.
IMG 8360 2
IMG 8363
IMG 8367
