appsandcode
Speed is the New Thrill
Can anyone help me with the below faults on a 2007 Audi S4 Cabriolet with 82000 miles on the clock? I have changed the plugs and ignition coils as well as try to swap them but still get the misfire.
VCDS
Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: Release 17.8.0(x64) Data version: 20170721 DS276.2 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000 000000
Self-Diagnosis Log Saturday,03,March,2018,11:49:31:00001
VIN: WUAZZZ8H47K901529 License Plate: PF07XWZ Mileage: 131950km-81989mi Repair Order: 001
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
63 65 67 73 75 76 77
VIN: WUAZZZ8H47K901529 Mileage: 131950km-81989miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E3 910 560 HW: 4E0 907 560 Component: 4.2L V8/5V G 0020
Revision: --H01--- Serial number:
Coding: 0011774
Shop #: WSC 00672 785 00200 VCID: 65C08908AC61C76E19-8030
2 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - 16685 - Cylinder 1
P0301 - 001 - Misfire Detected Readiness: 0110 1101
------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl
PartNoSW:8E1910156M HW:09L927156B Component: AG6 09L 4,2 MPI RdW 0030 Revision: --H01--- Serial number: 4313807 Coding: 0000001
Shop #: WSC 00672 785 00200 VCID: 31682D58A8295BCE35-8064
No fault code found. -------------------------------------------------------------------------------
VCDS
Self-Diagnosis Log Saturday,03,March,2018,11:49:31:00001 Page 2
Address 03: ABS Brakes Labels: 8E0-910-517.clb Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH Component: ESP8 quattro H06 0140
Revision: 00000000 Serial number: 00000000000000 Coding: 0004902
Shop #: WSC 00672 785 00200 VCID: 2E523624B917443628-807A
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent Freeze Frame:
Fault Status: 00100000 Fault Priority: 3
Fault Frequency: 1 Reset counter: 38 Time Indication: 0
Freeze Frame:
Hex Value: 0x0000 Hex Value: 0x4222 Hex Value: 0x0024 Hex Value: 0x0198 Hex Value: 0x0001
------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM Component: A4 Klimaautomat 3233 Coding: 00100
Shop #: WSC 00672
VCID: 6DD0F1282791FF2E51-515A
------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907 Coding: 21021
Shop #: WSC 00000
VCID: 3D7001683771AFAEA1-4B18
VCDS
Self-Diagnosis Log Saturday,03,March,2018,11:49:31:00001 Page 3
Address 15: Airbags Labels: 8H0-959-655-94.lbl PartNoSW:8H0959655E HW:8H0959655E Component: Airbag 9.42 H10 1840
Revision: 92H10184 Serial number: 0037Y000XFNT Coding: 0071114
Shop #: WSC 00672 785 00200 VCID: 3C760C6C7F6BA6A696-8068
Subsystem 1 - Serial number: 6332BRB4024ACCEF7 Subsystem 2 - Serial number: 6342BRB4024B2475H Subsystem 3 - Serial number: 63729RB40254DFC0Y Subsystem 4 - Serial number: 63829RB400318D77N
------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701 Coding: 03141
Shop #: WSC 00672
VCID: 41887D984B89CB4EC5-4B32
------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
PartNoSW:8H0920981S HW:8H0920981S Component: KOMBI+WFS 4 H10 0200
Revision: 0200 Serial number: 00000000000000 Coding: 0007401
Shop #: WSC 15146 000 104857 VCID: 408E789C1083C246CA-513C
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent -------------------------------------------------------------------------------
VCDS
Self-Diagnosis Log Saturday,03,March,2018,11:49:31:00001 Page 4
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl PartNoSW:8H0920981S HW:8H0920981S Component: KOMBI+WFS 4 H10 0200
Shop #: WSC 15146 000 104857 VCID: 408E789C1083C246CA-515A
1 Fault Found:
------------------------------------------------------------------------------- Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255 A
Component: VSG B6 CABRIO 7094 Shop #: WSC 00672 785 00200
VCID: 3466244C543B6EE65E-513C
3 Faults Found:
02000 - Switch Position
008 - Implausible Signal
01986 - Convertible Top Frame Position Sensor (G356)
012 - Electrical Fault in Circuit
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None
Part No: 8H0 959 760
Component: Sitzmemory EE H06 0010 Coding: 00002
Shop #: WSC 00065
VCID: 74E6E44C44BB2EE69E-4B18
3 Faults Found:
07-10 - Signal too Low - Intermittent
02010 - Left Entry Assistance Control Module (J572)
79-00 - Please Check Fault Codes
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - - -------------------------------------------------------------------------------
VCDS
Self-Diagnosis Log Saturday,03,March,2018,11:49:31:00001 Page 5
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb PartNoSW:8H0035192J HW:8H0035192J Component: RNS-E HIGH EU H73 0550
Revision: 02S Serial number: AUZBZ7G1202374 Coding: 0419757
Shop #: WSC 00672 785 00200 VCID: 2E523624BA17443628-5196
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent Freeze Frame:
Fault Status: 00100010 Fault Priority: 7
Fault Frequency: 1 Reset counter: 247 Time Indication: 0 Date: 2018.01.18 Time: 12:46:48
Freeze Frame: Voltage: 10.60 V
Mileage: 655350 km Count: 303
Clock: 11:37
16352 - Control Module - Electrical Error 014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110 Fault Priority: 5
Fault Frequency: 1 Reset counter: 186 Time Indication: 0 Date: 2017.05.08 Time: 15:56:50
------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0411 Coding: 00001
Shop #: WSC 00000
VCID: 6FECEB202D9D0D3E63-5178
VCDS
Self-Diagnosis Log Saturday,03,March,2018,11:49:32:00001 Page 6
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb Part No: 8H0 959 433 M
Component: Komfortgerát T3B 5342
Coding: 07851
Shop #: WSC 00672
VCID: 3E7206643A77B4B6B8-4B32
Subsystem 1 - Part No: 8H2959802D Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8H2959801D Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8H0959801A Component: Tõrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8H0959802A Component: Tõrsteuer.HR BRM 0002
6 Faults Found:
01616 - Signal Wire to Interior Monitor
79-10 - Please Check Fault Codes - Intermittent 01616 - Signal Wire to Interior Monitor
49-10 - No Communications - Intermittent 01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - - 00956 - Key 2
35-10 - - - Intermittent
------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010 Revision: 00000001 Serial number: Coding: 0000005
VCID: 3D7001686471AFAEA1-8068
VCDS
Self-Diagnosis Log Saturday,03,March,2018,11:49:32:00001 Page 7
Address 56: Radio Labels: 8E0-035-192-RNSE.clb PartNoSW:8H0035192J HW:8H0035192J Component: RNS-E HIGH EU H73 0550
2 Faults Found:
Clock: 11:37
Freeze Frame:
VCDS
Self-Diagnosis Log Saturday,03,March,2018,11:49:32:00001 Page 8
Address 63: Entry Assist,D Labels: None Part No: 8H0 959 760 A
Component: EasyEntry F M H13 0010 Coding: 00006
Shop #: WSC 00065
VCID: 356019480F4177EE69-4B18
2 Faults Found:
35-00 - -
------------------------------------------------------------------------------- Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H13 0010 Coding: 00005
Shop #: WSC 00065
2 Faults Found:
35-00 - -
------------------------------------------------------------------------------- Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
PartNoSW:8E0919283D HW:8E0919283D Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802020710 Coding: 0001124
Shop #: WSC 00672 785 00200 VCID: 31682D58AB295BCE35-5178
------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl
PartNoSW:8P0862335H HW:8P0862335H Component: FSE_255x BT H26 0290
Revision: 00000000 Serial number: 00000005123661 Coding: 0011802
Shop #: WSC 00672 785 00200 VCID: 3B740F707965A19E9F-515A
End-------------------------(Elapsed Time: 06:22)--------------------------
VCDS
Coding: 0011774
2 Faults Found:
VCDS
1 Fault Found:
Freeze Frame:
Shop #: WSC 00672
Shop #: WSC 00000
VCDS
Shop #: WSC 00672
1 Fault Found:
VCDS
1 Fault Found:
3 Faults Found:
Shop #: WSC 00065
3 Faults Found:
VCDS
2 Faults Found:
Clock: 11:37
Freeze Frame:
Shop #: WSC 00000
VCDS
Coding: 07851
Shop #: WSC 00672
6 Faults Found:
35-00 - -
35-00 - -
VCDS
2 Faults Found:
Clock: 11:37
Freeze Frame:
VCDS
Shop #: WSC 00065
2 Faults Found:
35-00 - -
Shop #: WSC 00065
2 Faults Found:
35-00 - -
