Which Ignition Coils for tuned motor ?
Lovric Nikola Martin
Gothenburg
I have had a software tuning done (stage 1) and today I had the EPC light and jerky running. So VCDS says code cylinder disable. After some research it seems the ignition coils should be replaced.
My question is which ignition coils are better than the standard ones for the S3 8V? Seems the Audi R8 coils are very popular but they dont fit in the S3 8V?
Before replacing, move the coils around and see if the misfires or error code comes back up on the specific cylinder you moved too.
Any coil works, but in my case it was the spark plugs that were the weakest link. Being stage 2, I was running I, but misfires. I then upgraded to colder plugs, the ikh27 and now no problems at all. The 27 are relatively cheap at $10 each on Amazon.
Sent from my Pixel 2 XL using Tapatalk
Thanks. I will try new plugs first since its a low cost anyway. Everything is stock. The fault code doesn't specify which cylinder? I will replace all spark plugs as a first step and see what happens.
Reactions: rcnacura
You should be able to get live data feed. Find the misfiring feed for each cylinder, then you can better pinpoint which cylinder is the problem.
Obdeleven directions, but should be somewhat similar.
Reactions: Rob2k68
I think I will replace the plugs anyway. Looking at Denso IKH27. Found a place that has them in stock. There are also recommendations for IKH24. Do you know what is the difference between these?
I would recommend using the RS7 plugs.....you can find what ones they are online quite easily
Reactions: Rob2k68
Yes I have been looking for the RS7 sparkplug with partnr 06K905601M but cannot find it in europe. Maybe part number is different here. I have sent an email to HS Tuning..
The ikh24 are one step, and ikh27 are two step colder. I personally would not use the rs7 plugs as they are overpriced and are a one step colder plug.
Who was the tuner ?
Fitted RS7 plugs to mine over the weekend all 4 for £35. They’re NGK plugs with iridium tips and one step cooler which is a similar spec to the NGK Race plugs I ran last time which cost £150+ !!!
Coil pack wise the latest revision coils are very good or if you feel like spending then the RS3 items will fit.
Reactions: PanamaS3 and rcnacura
Thats a real good price ! I payed £66 for the Denso IRH27 x 4 here in Sweden. I had trouble finding them so they were on special order. I checked the price for the RS3 coils with my closest Audi dealership and they are about £65 a piece. How do they differ from the original S3 coils?
Sounds like the dealers over there are having a laugh ! - half that over here for the RS3 coil packs.
I’ve no idea tbh but the tube part that goes over the spark plug looks fatter so I’m guessing better insulated/shielded and probably higher grade connectors.
Sent from my iPhone using Tapatalk Pro
looking to upgrade mine also, but read some were about you have to have certain set gap on them? all new to me this like lol any more info regarding this would be great.
were did you get your rs7 ones from mate if dont mind me asking
Most plugs come pre gapped to the correct gap but it doesn't hurt to check them.
There was a recent group buy on a Facebook group called 'Audi/VW/Seat/Skoda parts - mjr901' . Usual price is more like £55.
Reactions: lucaslfc
ah cool thanks mate, you dont happen to no the part num of these? think am seeing it as NGK Iridium IZKR7B after look on flea bay, but i may be wrong..
Sure, 06K 905 601 M
Reactions: lucaslfc
I get confused when searching for the "OEM Audi RS3 ignition coils" with part number 06H905110G. What is the actual brand / manufacturer for these, because I find 4-5 different makers of the same part.. Bosch, BERU, Bilstein, Delphi, NGK.
Where did you get yours from pal ?
There are multiple manufacturers- part number is 06H 905 110 G
.....so stage 1 has now occured then on the R @Rob2k68 ? REVO?
Reactions: Rob2k68
juts spoke to mike as Rob recommended, all ordered for the RS7 plugs :) great price aswel! :)
Reactions: PanamaS3 and Rob2k68
:hubbahubba: As tempting as it is to get it mapped I’m trying a few different things this time round, currently rocking a JB4 with custom map 6 which is really good :salute:
Reactions: Forbzeeee, lucaslfc and PanamaS3
hahaha nice......the force is weak in you young padwan lol
how does it compare to a proper map?
Reactions: lucaslfc and Rob2k68
can someone educate me in why these would need to be replaced from standard?
Reactions: PanamaS3
when you start modifying and tuning your car there is an overwhelming need to replace absolutely everything as OEM is seen as sub-standard lol
someone else needs to answer you properly....
Reactions: lucaslfc, welshy_a4 and Rob2k68
the plugs
Yep ...
The OEM plugs found in the RS7 can also be installed into your tuned MQB/8V vehicle for a step colder plug. A colder plug will cool off between combustion cycles faster than a plug with a larger pedestal. Since the plug is able to cool off between combustion cycles there is less heat in the combustion chamber which reduces the chances of detonation from an overly-hot combustion chamber. Colder plugs are a perfect compliment to your tuned vehicle.
Reactions: PanamaS3, Lovric Nikola Martin and lucaslfc
how much are we talking for them and how important are they to be changed in respect of incidents in this platform of incidents where the OEM plugs have failed
I enquired through messenger earlier this afternoon and he hasn't replied, is that the best way to get hold of him, do you know?
I gave him a call mate was quicker. Shud have them sat or monday.
Reactions: Jamesey78
So when buying the "OEM" RS3 ignition coils with the Audi dealership I can get any one of these "brands"? I just want to make sure I get the highest quality one
I believe so mate - think they’re all top brands tho so shouldn’t worry too much.
Reactions: Lovric Nikola Martin
