Saturday,14,October,2017,09:13:29:63362
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WAUZZZ8T9AA050596 License Plate: SN10 HNH
Mileage: 137160km-85227mi Repair Order:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72
77
VIN: WAUZZZ8T9AA050596 Mileage: 137160km-85227miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CCWA) Labels:| 059-907-401-V1.clb
Part No SW: 8R0 907 401 J HW: 8K1 907 401 A
Component: 3.0TDI EDC17 X03 0008
Revision: 15X03---
Coding: 0114002C240F0020
Shop #: WSC 26214 051 00000
ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
ROD: EV_ECM30TDI0118R0907401J.rod
VCID: 392C2564B9D6EAEF5C4-806C
2 Faults Found:
5182 - Particulate Trap Bank 1
P2002 00 [172] - Efficiency Below Threshold
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 137164 km
Date: 2017.10.12
Time: 05:56:41
Engine speed: 765.50 /min
Normed load value: 32.5 %
Vehicle speed: 0 km/h
Coolant temperature: 13 °C
Intake air temperature: 9 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.000 V
Unlearning counter according OBD: 40
Crankshaft speed (RPM): 765.5 /min
Vehicle speed: 0.00 km/h
Exhaust gas vol.flow particulate filter: 61.1 m³/h
Particle filter: difference pressure: -33 hPa
Particle filter: soot mass calculated: 8.81 g
Exhaust gas temp.after pre-catalyst: 35.1 °C
Intake air temperature: 10.0 °C
5262 - Diesel Particle Filter; Differential Pressure Sensor
P2454 00 [168] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Mileage: 137033 km
Date: 2017.10.09
Time: 15:00:25
Engine speed: 0.00 /min
Normed load value: 0.0 %
Coolant temperature: 22 °C
Intake air temperature: 18 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.100 V
Crankshaft speed (RPM): 675.5 /min
Particle filter: difference pressure: -50 hPa
Intake air temperature: 17.3 °C
Exhaust gas temp.after pre-catalyst: 81.5 °C
Particle filter: offset for differential press.: 1 hPa
Exhaust gas vol.flow particulate filter: 38.3 m³/h
Readiness: 1 2 0 0 0
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K1 927 156 A HW: 0B5 927 156 E
Component: 0B5 30 TDIRdW H03 0002
Revision: --H03--- Serial number: 0000000208
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501 A02044
ROD: EV_TCMDL501.rod
VCID: 3330174C9BBA10BF968-8066
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BC HW: 8K0 907 379 BC
Component: ESP8 quattro H04 0020
Revision: -------- Serial number: --------------
Coding: 1C0500
VCID: 7BA0FF6CF3EA18FF0E8-802E
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0327
Revision: 00002001
Coding: 011400
VCID: 015C8D849106722F544-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0510000001167001
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000108735005
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Component: KLIMA 3 ZONEN H08 0171
Revision: D0000000 Serial number: 01130120101559
Coding: 36040000
VCID: 76B6EE58C8C84597716-8022
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H25 0380
Revision: 09025001 Serial number: 00000000556040
Coding: 260050914034AF010009000000005D5D4F1D430800010141000000
Shop #: WSC 06325 123 12345
VCID: 3A2E3A68BC50E1F755E-806E
Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 151209 H12 0070
Serial number: SWF09120150230
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10737500
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000002312090547
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 Q HW: 8K0 919 475
Component: PARKHILFE 4K H06 0070
Revision: 11001001 Serial number: 51231000501677
Coding: 10010F
VCID: 47C8539CFFA28C1FDA0-8012
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H39 0560
Serial number: 003EFD08VKHZ
Coding: 30363438363030303030554A305238543053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 41DC4D84D106B22F144-8014
Crash sensor for side airbag: driver side:
Serial number: 6334MSME4F360551C
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME4D15047DL
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME5048060EE
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME074A133EK
Crash sensor for front airbag: driver side:
Serial number: 63732SME6C4A300E5
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME6C4A2016+
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319JA8000GW
Coding: 000032
VCID: 3D243174AD7ED6CF70C-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 K HW: 8T0 920 981 K
Component: KOMBIINSTR. H34 0255
Revision: 00000000 Serial number: CI266Z71A
Coding: 2F07310002002600010000
VCID: 44D24490CE94A7073F2-8010
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0105
Revision: GB600050 Serial number: 5000G101068317
Coding: 00C303
VCID: 50FA78C00AEC4BA78BA-8004
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 190A0866031209
1 Fault Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 7
Reset counter: 114
Mileage: 136953 km
Time Indication: 0
Date: 2017.10.06
Time: 16:43:40
Freeze Frame:
Bin. Bits: 10000
Voltage: 13.90 V
Count: 8
Bin. Bits: 10000
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 J HW: 8T0 959 793 D
Component: TSG FA H07 1201
Coding: 011C02624001450005
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0125373411
Coding: 013B0622203904000020043280000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOC.clb
Part No SW: 8T0 035 223 AR HW: 8T0 035 223 AJ
Component: DSP Prem H19 0320
Revision: 00019001 Serial number: 34835000440902
Coding: 0203010301
Shop #: WSC 00505 210 91477
VCID: 7EA6F678E0F80DD7296-802A
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Mileage: 136953 km
Time Indication: 0
Date: 2017.10.06
Time: 16:29:53
Freeze Frame:
Voltage: 13.30 V
Temperature: 38.0°C
Temperature: 47.0°C
Bin. Bits: 00000001
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 J HW: 8T0 959 792 D
Component: TSG BF H07 1201
Coding: 011C02224C01450005
VCID: 4FF87BBC17D2545F920-801A
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000408162
Shop #: WSC 00000 000 00000
VCID: 343214509E3417878F2-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000002
Shop #: WSC 06324 000 00000
VCID: 77A8E35CC3C23C9F6A0-8022
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 P HW: 8T2 035 186 P
Component: Concert3 H04 0310
Revision: 00000007 Serial number: AUZ5Z6J1332948
Coding: 0503008201040D00835B070000
VCID: 45D45994C5AE9E0F28C-8010
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8T0 959 795 J HW: 8T0 959 795 B
Component: TSG HL H05 1201
Coding: 010C02224001450005
VCID: 52FE72C804E039B7BDE-8006
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H05 1201
Address 77: Telephone Labels: RETROFIT77.lbl
Part No SW: KTC 364 31P HW: KTC 364 31P
Component: SWP:3.31.6 H24 0220
Revision: 00000000 Serial number: 00000000000000
Shop #: WSC 21977 142 74100
VCID: 3330174C973A10BF968-8066
End----------(Elapsed Time: 01:32, VBatt start/end: 14.5V/14.5V)-----------
Address 01: DTCs cleared
