What are the benefits of controlling exhaust valves? Serious question.
The car is nuts at 3-4k rpm though, why you would want that "all the time" is beyond me.
TX.
Sent from my STV100-4 using Tapatalk
Thanks guys so I'll just unplug when ignition off and I'll be good to have valves open all the time just like the pfl S3
Are you guys 100% sure they are shutting in dynamic and that you are not just getting caught out by the feature that stops them being started in full dynamic mode?
On my B8.5 RS4 everyone said the same but i didn't believe them and tested it with vcds. Sure enough dynamic meant the valves were open 100% of the time. What caught people out was the need to cycle the modes after you start the car because it will never start with the engine or box settings in dynamic even when it says it's in dynamic. This is to stop "unexpected dynamic driving characteristics" after a driver change.
Yes but have you done that when after you start it you click the drive select button to cycle all the way back round to dynamic?110% sure. My mate pulls off in his S3 with them still connected, as he passes a few mph you hear the valves operate and the sound change. I've heard it on the RS3, as soon as it moves off the noise changes and the valves definitely don't open until past 3000rpm.
Got you. Ok it is different then. Comfort on mine is the same as auto. It only has open all the time or as described above.Yes, still does it. If in comfort etc, the valves don't open until you pass a really high threshold (5k or along those lines). Thinking about it, for your car that's not high![]()
Thought it was worth checking as the whole internet said mine was like you describe and everyone plugged the vacuum then it turned out to be that BS cant start in dynamic 'feature'.
I'd imagine this would make a nice difference on a highly boosted single bank engine. Unplugging them actually lost me 12lbft torque low down on the V8
Which valve control units have/Are people using?
Yes you have to think a n/a twin bank engine will be very sensitive to back pressure and therefore exhaust scavenging. On the boosted 5 pot it should only be a good thing to have them open.They definitely open and close, I've come across a few cars now that I've witnessed in person without the ones I've seen online.
But I can't comment on the RS4, haven't noticed that. Did you really lose power? Shouldn't make any difference with valves.
4% below 3500rpm - you'd never feel it. And anytime you are having fun it never drops below 7k rpmI suppose, that's a good point and susprising it made a fairly big change considering.
Doesnt show for new model RS3
I'm assuming just like the pfl S3 the valves are open by default when the ignition is off
So all I did was unplugged the two connectors and they were open all the time
Can any facelift S3 and pfl Rs3 and fl Rs3 owners confirm this?
