2005 A8 D3
Devilz
Active Member
Birmingham, England
I had A8 D3 today for some vcds tweaks but due to battery issue couldn't do much. The battery died half way through while I was trying to clear the fault codes so after jump start. Had to re run the auto-scan and clear the fault codes. Almost every code was voltage related. Need advise what could be the cause of it.
Code:
Saturday,22,July,2017,18:15:32:25423
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WAUZZZ4E36N001868  License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 18 19 1D 1E 25 28
  34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 69 72 76
  77
VIN: WAUZZZ4E36N001868  Mileage: 173890km-108050miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Not registered 0001
67-Voice Control -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine  Labels: Redir Fail!
  Part No SW: 4E0 910 409 H  HW: 4E0 907 409 C
  Component: 4.0L V8TDI  A000AGMª0010
  Revision: --H01---  Serial number: AUX3Z0E3362460
  Coding: 0010773
  Shop #: WSC 02313 785 00200
  VCID: 285FA89A9B90540181-807C
1 Fault Found:
17861 - Exhaust Gas Temp Sensor 1 (G235)
  P1453 - 000 - Open or Short to Plus
  Freeze Frame:
  RPM: 651 /min
  Torque: 89.7 Nm
  Speed: 0.0 km/h
  Duty Cycle: 0.4 %
  Voltage: 13.53 V
  Temperature: 690.2°C
  Temperature: 145.0°C
  Inj. Quantity: 8.2 mg/str
Readiness: 0 0 1 1 1
Address 02: Auto Trans  Labels: 09E-927-156.lbl
  Part No SW: 4E1 910 156 L  HW: 09E 927 156 A
  Component: AG6 09E 4,0LTDI RdW 0020
  Revision: --H01---  Serial number:  0056576
  Coding: 0000001
  VCID: 2C57548A8F68782165-8078
No fault code found.
Address 03: ABS Brakes  Labels: 4E0-910-517.lbl
  Part No SW: 4E0 910 517 B  HW: 4E0 614 517 BC
  Component: ESP 5.7 allrad  H44 0510
  Coding: 0008557
  Shop #: WSC 02313 000 00000
  VCID: 224BBAB2FDACBE51DF-8076
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
  000 -  -
Address 05: Acc/Start Auth.  Labels: 4E0-910-131.lbl
  Part No SW: 4E0 910 131  HW: 4E0 907 181 A
  Component:  FBS AUDID3  H12 0200
  Revision: 02005112  Serial number: AUX3Z0E3362460
  Coding: 0265216
  Shop #: WSC 01223 210 182671
  VCID: 58BFD85AEB702481F1-800C
  Subsystem 1 - Part No: XXXXXXXXXXX
  Component: ELV  XXXX
Address 06: Seat Mem. Pass  Labels: None
  Part No SW: 4E0 910 760 C  HW: 4E0 959 760
  Component: Sitzmemory BFS H08  0060
  Revision: 00000000  Serial number: 5DS 008 795-03
  Coding: 4063328
  VCID: 2345BFB6E2B6B759D4-8076
Address 07: Control Head  Labels: 4E0-910-7xx-07.lbl
  Part No SW: 4E0 910 730 F  HW: 4E0 035 729 A
  Component: Interfacebox  H43 1110
  Revision: 00000000  Serial number: 300D9057550044
  Coding: 0000002
  Subsystem 1 - Part No: 4E0 910 611
  Component: E0380 BedienteilH01 0050
  Subsystem 2 - Serial number: 00000000095911
  Subsystem 3 - Serial number: 0128.03.120000000100010021ÿ
  Subsystem 4 - Serial number: 010021ÿ
Address 08: Auto HVAC  Labels: None
  Part No SW: 4E0 910 043 B  HW: 4E0 820 043 D
  Component: KLIMAAUTOMAT  016 0400
  Revision: 00000030  Serial number: 00000000064940
  Coding: 1136817
  Shop #: WSC 02311 785 00200
  VCID: 1C37844ADFC888A115-8048
Address 09: Cent. Elect.  Labels: 4E0-910-279.lbl
  Part No SW: 4E0 910 279 L  HW: 4E0 907 279 L
  Component: ILM Fahrer  H12 0210
  Coding: 0143121
  VCID: 316945FEA84A15C956-8064
  Subsystem 1 - Part No: 4E2 910 113 B
  Component: Wischer WWS D3  H50 0420
  Coding: 00000037
  Shop #: WSC 02313
  Subsystem 2 - Part No: 4E0 910 557  Labels: 8K0-955-559.CLB
  Component: REGENLICHTSENSORH10 0050
  Coding: 00139548
  Shop #: WSC 02313
Address 11: Engine II  Labels: Redir Fail!
  Component: 4.0L V8TDI  A000AGSª0010
  Coding: 0010773
Address 13: Auto Dist. Reg  Labels: None
  Part No SW: 4E0 910 561 F  HW: 4E0 907 561 F
  Component: ABSTANDSREGELUNGH03 0020
  Coding: 0011155
  VCID: 2541A1AEEC824969BA-8070
1 Fault Found:
01316 - ABS Control Module
  013 - Check DTC Memory - MIL ON
  Freeze Frame:
  Fault Status: 11111101
  Fault Priority: 5
  Fault Frequency: 1
  Reset counter: 74
  Mileage: 173892 km
  Time Indication: 0
  Date: 2017.07.22
  Time: 00:34:00
  Freeze Frame:
  Temperature: 30.0°C
  Voltage: 13.95 V
  Bin. Bits: 00100100
Address 15: Airbags  Labels: 4E0-910-655-84.lbl
  Part No SW: 4E0 910 655  HW: 4E0 959 655 G
  Component: Airbag 8.4E+  H10 0940
  Coding: 0431707
  VCID: 63C5FFB6A236F75994-8036
Address 16: Steering wheel  Labels: 4E0-910-549.lbl
  Part No SW: 4E0 910 549  HW: 4E0 953 549
  Component: Lenksäulenmodul H13 0040
  Coding: 0112151
  VCID: 65C1E1AEAC0289697A-8030
  Component: Lenkradmodul  H07 0080
Address 17: Instruments  Labels: 4E0-910-xxx-17.lbl
  Part No SW: 4E0 910 980 N  HW: 4E0 920 980 N
  Component: KOMBIINSTR. VDO H70 0400
  Revision: D01  Serial number: AUDID3E3000186
  Coding: 0016413
  Shop #: WSC 39809 067 57207
  VCID: 326B4AF2AD4C2ED12F-8066
Address 18: Aux. Heat  Labels: None
  Part No SW: 4E0 910 105 A  HW: 4E0 815 069 E
  Component: Heizgeraet  H07 0100
  Revision: 0000000B  Serial number: 00000009006406
  Coding: 0000001
  Shop #: WSC 00000 000 00000
  VCID: 1A3B8252D5FCF69107-804E
Address 19: CAN Gateway  Labels: 4E0-910-468.clb
  Part No SW: 4E0 910 468 B  HW: 4E0 907 468 F
  Component: Gateway  H10 0080
  Revision: 10  Serial number: 1800405322004E
  Coding: FFFFFFDE2B7504
  VCID: 275DABA6968E5B7988-8072
1 Fault Found:
01044 - Control Module Incorrectly Coded
  000 -  -
  Freeze Frame:
  Fault Status: 01100000
  Fault Priority: 1
  Fault Frequency: 1
  Reset counter: 74
  Mileage: 173894 km
  Time Indication: 0
  Date: 2017.07.22
  Time: 00:26:15
Address 1D: Driver Ident.  Labels: 4E0-910-218.lbl
  Part No SW: 4E0 910 218 A  HW: 4E2 905 218 B
  Component: FPI_1  H01 0010
  Revision: 01000101  Serial number: 31012005175649
  VCID: 1F4DB346CEDE93B9F0-804A
Address 1E: Media Player 2  Labels: 4E0-910-111.lbl
  Part No SW: 4E0 910 111 E  HW: 4E0 035 111 A
  Component: CD-Changer  H44 0430
  Revision: 00000000  Serial number: AUZ5ZBE7145383
  VCID: 1B358756DAC68F991C-804E
Address 25: Immobilizer  Labels: 4E0-910-131.lbl
  Coding: 0265216
  Component: ELV  XXXX
  XXXXXXXXXXX ELV  XXXX
Address 28: HVAC, Rear  Labels: None
  Part No SW: 4E0 910 158  HW: 4E0 919 158 A
  Component: KLIMA-STG. FOND 015 0220
  Revision: 00000018  Serial number: 00000000026399
  Coding: 0000000
  VCID: 61C9F5BEB82AE54986-8034
Address 34: Level Control  Labels: 4E0-910-553.lbl
  Part No SW: 4E0 910 553 J  HW: 4E0 907 553 F
  Component: LUFTFDR.-CDC  H06 6310
  Coding: 0015520
  Shop #: WSC 00011 888 06946
  VCID: 2A5B5292859C661197-807E
Address 36: Seat Mem. Drvr  Labels: None
  Component: Sitzmemory FS  H08  0060
  Coding: 4063342
Address 37: Navigation  Labels: 4E0-910-88x-37.lbl
  Part No SW: 4E0 910 887 L  HW: 4E0 919 887 C
  Component: MNS ECE  H44 0690
  Revision: 00000000  Serial number: 305DM057583037
  VCID: 366376E2412432F103-8062
Address 38: Roof Electronics  Labels: 4E0-910-135.lbl
  Part No SW: 4E0 910 135 A  HW: 4E0 907 135 A
  Component: Dachknoten D3  H02 0090
  Serial number: 00000504700025
  Coding: 0036038
  VCID: 1D31894EC4D281A9E2-8048
Address 42: Door Elect, Driver  Labels: 4E1-910-802-42.lbl
  Part No SW: 4E1 910 802 B  HW: 4E2 959 802 B
  Component: Türsteuer.FS BRM003 0060
  Coding: 0028462
  VCID: 204FB0BAF3A0AC41C9-8074
Address 46: Central Conv.  Labels: 4E0-910-289.lbl
  Part No SW: 4E0 910 289 A  HW: 4E0 907 289
  Component: Komfortgeraet  H04 0040
  Revision: 00400004  Serial number:  W040504050026
  Coding: 0004317
  Subsystem 1 - Part No: 4E0 907 719
  Component: Neigungssensor  H03 0020
Address 47: Sound System  Labels: 4E0-910-223.lbl
  Part No SW: 4E0 910 223 K  HW: 4E0 035 223 A
  Component: DSP-Amp.-High  H13 0440
  Revision: PROD_01  Serial number: 00000000013092
  Coding: 0000011
Address 4F: Centr. Electr. II  Labels: None
  Part No SW: 4E0 910 280 A  HW: 4E0 907 280 A
  Component: ILM Beifahrer  H09 0040
  Revision:  Serial number: 00000000059086
  Coding: 0010101
  VCID: 1E338E42C9D49AB1FB-804A
Address 52: Door Elect, Pass.  Labels: 4E1-910-802-52.lbl
  Part No SW: 4E1 910 802 B  HW: 4E2 959 801 B
  Component: Türsteuer.BF BRM003 0060
  Coding: 0028462
Address 53: Parking Brake  Labels: 4E0-910-801.clb
  Part No SW: 4E0 910 801 A  HW: 4E0 907 801
  Component: EPB  AV1C1010  H01 1010
  Revision: AV1C1010
  Coding: 0000431
  Shop #: WSC 00383 210 80878
Address 55: Headlight Range  Labels: 4F0-910-357.lbl
  Part No SW: 4F0 910 357 C  HW: 4F0 907 357 C
  Component: AFS 1  H01 0020
  Revision: 00000001  Serial number:
  Coding: 0000018
  VCID: 2643A6A291844271B3-8072
  Subsystem 1 - Part No: 4F0 941 329 A
  Component: AFS-Modul links H05 0010
  Subsystem 2 - Part No: 4F0 941 329 A
  Component: AFS-Modul rechtsH01 0010
Address 56: Radio  Labels: 4E0-910-541.lbl
  Part No SW: 4E0 910 541 F  HW: 4E0 035 541 E
  Component: TUNER EU/US/RDW H42 0480
  Revision: 00000000  Serial number: 396DR057507702
  Coding: 0000001
Address 57: TV Tuner  Labels: 4E0-910-146.clb
  Part No SW: 4E0 910 146 E  HW: 4E0 919 146 B
  Component: TV analog TUNER H13 0270
  Revision: 00000010  Serial number: 00000000001317
  Coding: 0001003
Address 61: Battery Regul.  Labels: 4E0-910-181.lbl
  Part No SW: 4E0 910 181 C  HW: 4E0 915 181 C
  Component: ENERGIEMANAGER  H12 0480
  Revision: 00000000  Serial number: 00000000005469
  Shop #: WSC 00958 210 51185
  Subsystem 1 - Part No: 4E0 915 105 A
  Component: von VA0  300410A23L
  Coding: 34453039313531303541205641303330303431304132334C
  Shop #: WSC 00383 210 83674
Address 62: Door, Rear Left  Labels: 4E0-910-802.lbl
  Part No SW: 4E0 910 802 A  HW: 4E0 959 801 C
  Component: Türsteuer.HL BRM003 0060
  Coding: 0028462
Address 65: Tire Pressure  Labels: 4E0-910-273.lbl
  Part No SW: 4E0 910 273  HW: 4E0 907 273
  Component: Reifendruck 2  H01
  Revision: 00010028  Serial number: 00000700031509
  Coding: 0202328
  VCID: 5FCDF3468E5ED3B9B0-800A
1 Fault Found:
01477 - System Switched Off
  000 -  -
  Freeze Frame:
  Fault Priority: 4
  Fault Frequency: 1
  Reset counter: 74
  Mileage: 173894 km
  Time Indication: 0
  Date: 2017.07.22
  Time: 00:32:21
  Freeze Frame:
  Speed: 0.0 km/h
  Temperature: 19.0°C
  Error Code: 0
  Not Recogn.
  Not Recogn.
  Not Recogn.
  Not Recogn.
Address 67: Voice Control  Labels: 4E0-910-75x-67.lbl
  Part No SW: 4E0 910 754 D  HW: 4E0 035 753 A
  Component: SDS 3502 UK  H45 0560
  Revision: 00000000  Serial number: 00000503300059
  Shop #: WSC 12336 024 394758
Address 69: Trailer  Labels: 4E0-910-383.lbl
  Part No SW: 4E0 910 383 B  HW: 4E0 907 383 B
  Component: ANHAENGERELEKTR 003 0040
  Coding: 0000001
Address 72: Door, Rear Right  Labels: 4E0-910-802.lbl
  Part No SW: 4E0 910 802 A  HW: 4E0 959 802 C
  Component: Türsteuer.HR BRM003 0060
  Coding: 0028462
Address 76: Park Assist  Labels: 4E0-910-283.lbl
  Part No SW: 4E0 910 283 A  HW: 4E0 919 283 B
  Component: Parkhilfe 8-Kan H12 0020
  Revision: 06.00.57  Serial number: 00067808720509
  Coding: 0111108
  VCID: 2149B5BEF8AAA549C6-8074
Address 77: Telephone  Labels: 4E0-910-336.lbl
  Part No SW: 4E0 910 336 C  HW: 4E0 862 335
  Component: Handyvorb2  H10 0120
  Revision: 00000000  Serial number: 00000007548564
  Coding: 0010900
End-------------------------(Elapsed Time: 03:46)--------------------------
I may not be reading the report properly but I only see 2 faults recorded. £ if counting tyres pressure.
If the battery is weak car is switching off some systems. I had some glitches in my D3 after purchase but they disappeared after I put new battery in.
940
10
15K
