pipe blockage
ch1z64
C'mon you's bhoy's in Green
Silver Supporter
Kilwinning Ayrshire
can anyone direct me on how to unblock a washer pipe as my back one wont put any water down onto back window , now the pump is working so just needing to know how i fluah through the rubber pipe work and hope the sh*t in it goes thanks in advance
Replace the jet below the rear wiper cap.
I used a pin to unblock mine. And pushed with some air from an air pump at the garage.
Sent from my Swift 2 Plus using Tapatalk
right since i was removing boot door card i tried my back wiper washer and no joy so it looks like it is an internal blockage ie pipe as i got the neighbour to hold the pipe once i removed it from where it should push the water down through , started car and nothing came out the hose end so how i am going to find the blockage beats me other than taken all the pipework apart unil i find where the water starts to flow
The washer won't work with the boot open.
ok mate never knew that . will try with it cloaed and double check that spray bit your on about
had to buy a new spray nozzle fae Audi just under a tenner was cheaper to buy a av connector just typical
Genuine part fits and works first time with a 2 year parts warranty.
737
643
23
906
435
