Multi-function steering wheel
Karlgray_92
31
Need some advise... av been looking at getting a multi-functional steering wheel for my a4 b7.... the one i have now has no buttons on it, so will a one with buttons work?? And also looking for a good induction kit.
It depends on your sccm.
Do you have cruise control?
If you do you just need to swap steering wheels and code it.
If not you'll need a new sccm too and then code the abs module before carrying out with the coding for the steering wheel..
Sent from my SM-G935F using Tapatalk
Yeahh i have cruise control... thats great thanks, where would i get the code from?
If you have cruise control means your module also accepts mfsw and its a case of installing said steering wheel and code it.
The coding is already in the car.. Needs to be enabled with VCDS.
Reactions: Alex Ward
