Hi there....you need to talk to
@TTE Si
The whole idea of the hybrids is being able to run a good bit of power without a ful engine build,and by using a hybrid,you keep the torque down.
The safe limit of the stock rods is 440lbs or thereabouts,and providing you don't exceed that,you don't need a full engine build.
If you did decide to do so,there is no point in just swapping the rods out,and you should change the Pistons,rods,bearing shells etc all at the same time.
Have a plough through my build thread for what you can and can't do on a stock engine....
I'm not sure what you mean by a Stg2 clutch.....do you mean a Spec Stg2 clutch or a stock clutch running Stg2 power/torque?
Either way,a stock clutch will not survive what you have in mind,and my recommendation would be a Spec Stg2+or Stg3 clutch,as I've used,and others here do too.
Those will cope with a fair amount of torque(my old Spec Stg3+ Finally gave in at 540lbs).
The gearbox is good also for around 500-540lbs,but may require uprated bearings and synchros may also wear.
The LP fuel pump will also need attention,some of us use the RS pump and an uprated PWM controller,and you will need RS3 injectors,plus custom mapping.
Rick@Unicorn is one of the best to speak to about mapping this setup.
