Ok so on fitting the badger tip I ended up breaking what I believe to be the evap check valve from original tip. I was going to do evap delete but since I have a bam engine it sounds like the chances of it throwing up an error is high so the only option I see is to replace the check valve.
I don't fancy paying out for an original tip just for the valve.
Can I not just buy a 1 way check valve of ebay or something?
Read you can use a valve from the n249 which I have deleted?
Is the part available from audi separate to tip?
thanks.
thanks.
