S3Imola_Alex
- Joined
- Feb 10, 2017
- Messages
- 23
- Reaction score
- 2
- Points
- 3
Hi Everyone!
This is my first post. I've been reading this forum for a while and now is the first time I've had to start a new thread. I have looked but can't find one which answers my questions. I hope you can help?
I recently bought a 2002 Audi S3 8L (BAM engine). It's done 160000 miles, drives well, turbo works fine all is good...
Now on viewing the car all seemed fine, however when I returned to collect it i noticed that it wasn't getting up to the correct temperature on the motorway. I had this problem before on my A3 and plan on replacing the thermostat this weekend. No issue there.
However today I was doing a little engine check and realised a small amount of the dreaded "mayo" on the dipstick. I opened up the oil filler cap and surprise surprise a thin spreading of mayo on there too!
Now one problem that I noticed when I viewed the car was that the oil filler cap "neck" was loose. This meant that there isn't an airtight seal to the engine.
What I want to know is, could moisture be getting in around the gap between the neck and the engine causing the milky deposits? And as the thermostat is fully open all the time the engine isn't getting up to a high enough temperature to burn it off.
I feel this could be the case, rather than jumping the conclusion of head gasket failure. (Coolant levels are still ok)
Now I have read that on some VWs you can remove the "neck" and screw the filler cap straight into the engine. Has anyone tried this? I don't want to break the neck off and find the cap doesn't fit.
Do you think it would be ok to still drive the car on the gamble that it's not the head gasket that's gone but a combination of the things mentioned above?
Sorry for the long post, just trying to be thorough!
Alex
Alex
