Hi All
I recently purchased the above car; it had defective gears on the throttle body and was giving a P3103 – Motor for intake manifold flap error (V157). Due to this the valve was replaced and the EGR (heavy carbonised) has been cleaned and new seal. Now the engine management light does not come on.
When idle (cold or warm) the engine misfires on an inconsistent basis (perhaps 10 times per minute), also when stationary, if you press the accelerator the engine and body moves\rocks to the right. This is noticeable by monitoring the top of the bonnet.
As I have limited service information on the car, a service was carried out (oil, air, pollen filers) and fuel filter changed. I am using TRIPLE QX Engine Oil - 5W-40 (Fully Synthetic) Engine Oil and Shell V-power diesel.
I am new to VCDS and VAG cars; I have run VCDS on the system and no faults are highlighted.
What can be the cause? If I need to use VCDS to run checks please kindly detail the steps involved.
