VCDS scan
s3reptdi
Kettering, Northamptonshire
Hi everyone, wasn't sure wether to put this in the VCDS chat or not?
Wondering if anyone could help me with these codes please? My heater is really weak coming out of the vents and doesnt sounds very powerful when on full power which probably relates to these codes. As for the others ive no idea. Any quick rersponses would be much appreciated as theres one being broken a mile down the road from me and he will be scrapping it soon.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 M HW: 8P0 820 043 M
Component: KlimavollautomatH18 0260
Revision: 291325 Serial number: 8P0820043M
Shop #: WSC 06314 000 00000
VCID: 3663983741DF40F256-8062
2 Faults Found:
00483 - Control Module for Auxiliary Air Heater
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 35
Mileage: 184855 km
Time Indication: 0
Date: 2017.01.13
Time: 15:20:36
Freeze Frame:
ON
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 99
Reset counter: 11
Mileage: 163542 km
Time Indication: 0
Date: 2013.05.30
Time: 08:50:53
Freeze Frame:
Temperature: 13.5°C
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H34 0301
Revision: 00H34000 Serial number: 00000001490531
Coding: A9885F36A214100F00000000000000000011FE0F5C
Shop #: WSC 01236 785 00200
VCID: 3D71871B64E993AA97-8068
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 01236
1 Fault Found:
01800 - Light Switch (E1)
008 - Implausible Signal
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001033742
Shop #: WSC 00000 000 00000
VCID: 70EF6E2F633B2EC24C-8024
2 Faults Found:
02247 - Subwoofer (R148/R157)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 83
Mileage: 184802 km
Time Indication: 0
Date: 2017.01.12
Time: 14:26:44
Freeze Frame:
Temperature: 12.0°C
Raw, Form. N/A: 000 000 000
00422 - Rear Right DSP Midrange Speaker (R106)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 31
Mileage: 184802 km
Time Indication: 0
Date: 2017.01.12
Time: 14:26:44
Freeze Frame:
Temperature: 12.0°C
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D51B75BB489032A27-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
i found if you check out or even join the ross tech forum you might find the answers and help there all the best
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 D
Component: Heizgeraet H08 0080
Revision: 0000000C Serial number: 00000009014264
Coding: 0000001
Shop #: WSC 31414 790 00001
VCID: 60C86CA2B32FBE4189-8034
1 Fault Found
00664 - Fuel gauge
002 - Lower Limit Exceeded - Intermittent
Can any one help me with this problem please i need to know what needs to be done to sort this fault out on my Audi Q7 3.0 v6 tdi 2007
967
