Have you found a pinout for connection D?
I did. workshop-manuals.com is an excellent resource. Here is the entire pinout.
http://workshop-manuals.com/audi/a3...527_multi-pin_connector_assignments/page_337/
http://workshop-manuals.com/audi/a3...527_multi-pin_connector_assignments/page_338/
E
Ignition switch/ignition key removal lock connector mount
Not used
Not used
Ignition key removal lock on terminal 30
Ignition switch ground
Not used
Not used
Ignition switch output terminal 50
Voltage supply terminal 30 to ignition switch
9
Out put ignition switch terminal S
10
Output ignition switch terminal X
Output ignition switch terminal P
12
Output ignition switch terminal 15
F
Connector mount wiper system/DIS
Windshield washer switch signal
Windshield washer ground
Signal wiping rear lid/washing
Not used
DIS signal
DIS/interval potentiometer ground
Signal interval speeds
Not used
G -
Spiral spring/airbag/ steering wheel heating/multi-function steering wheel/signal horn connector mount
Heated steering wheel "+"
Heated steering wheel "-"
Airbag 1 "+"
Airbag 1 ""
Airbag 2 "+"
Airbag 2 ""
Ground (for coil spring/multi-function steering wheel/horn)
Cruise control locked "Off" /horn signal
9
Temperature signal on steering wheel heating
10
Voltage supply terminal 15 with multi-function steering wheel
H -
Steering angle sensor connector mount
Light barrier 5
Light barrier 1
Light barrier 1
12 V voltage supply
5 V voltage supply
Light barrier 6
Light barrier 4
Light barrier 2
9
Steering angle sensor ground
10
Light barrier 7.
C -
Electrical system connector mount
1. Taxi radio telephone 2
2. Taxi radio telephone 1
3. Taxi alarm 2
4. Taxi alarm 1
5. not used
6. not used
7. not used
8. not used
9. not used
10. Powertrain CAN-Bus, shielding
11. Powertrain CAN bus Low
12. Power CAN bus high
13. Cruise control latched Off
14. Comfort CAN bus high
15. Comfort CAN bus Low
16. P-IN (Selector lever P contact)
17. Auxiliary output terminal 15
18. Auxiliary output terminal 50
19. Terminal 30 voltage supply
20. Terminal 31 voltage supply.
D -
Airbag control module connector mount
1. Airbag 1
2. Airbag 1 +
3. Airbag 2 +
4. Airbag 2
