garratt83 said:leecs3, can I ask which bulbs you bought for each:
Front
Rear
Interior
Buster said:They just pull out, keep trying and you will get them out.
vanilla_ice said:Does removing the battery cause any problems - radio codes etc?![]()
It will be the first time I have had to do it.
Cheers,
ICE
leecs3 said:No need unless you have big hands!! Loosen of the battery holding strap or remove it and unclip the plastic holder that fitted around the back and sides of the battery so you can move the battery around by a couple of inches. Best way to get at the bulb is to stand with you right hand side against the wing, reach in and just wiggle the bulb with a slight pull from varying angles. It will pop out easily when its ready. Don't force it.
Ed said:Replaced my LEDs with the standard ones.
The LED's from ebay looked really good, and tbh i didnt expect anything different for the money i paid! Well worth the money, even though they failed!
They looked a bit silly with normal halogen lights tbh. I won't be buying any more unless/untill i get some HID main beams
voorhees said:miserable shits can't even thank not in person
