engine mounts
73pop
lancashire
Is any body running uprated ones or have any suggestions? This is the next on my list as i work to stage3.
Good black friday deal would be good:smiley:
Not yet but also toying with this .... Revo have just launched some and will be doing some BF discounts ;o)
Reactions: pburv
Had vibratechnic mounts on my old mk1 focus rs, stiffened the front end up no end, but did cause it to be quite rattly, then again it was a 14 year old Ford!
Not sure if they do them for the audi but would have thought they would.
Reactions: pburv, Rob2k68 and 73pop
A good start would be the 034 motorsports engine mount insert. I have it on my Mk7R and tightened up the engine movement noticeably with no extra vibrations at all.
Reactions: batch, RedRS3Reilly, pburv and 2 others
Not seen this ..... easy to fit ?
Reactions: pburv
Ah, are you referring to the dogbone mount at the torque arm bushing strap to gearbox ?
Reactions: pburv
Think the guy with the red stage 3 car fitted this to his takes pressure of the transfer box think he said
Reactions: pburv and Rob2k68
I have one on mine - it's helped a lot to eliminate the occasional notchy abrupt gear changes. For what it costs pretty much a must have.
Reactions: zippster and pburv
have been toying with this also ? worth it? easy to fit? do i need a lift to fit one?
Thanks in advance
Reactions: 73pop, Rob2k68 and pburv
Thanks in advance
Yes do it !!
Only potential issue is if the engine moves when you remove the bolt to fit the 034 mount - you may then need a mate to pull from the back of the engine forward so that you can get it bolted back up. Much easier to do if off the ground on a ramp.
American but try Black Forest industries. All 3 mounts are around $400 and probably have a BF sale.
Reactions: Rob2k68
Yes do it !!
so if i drove up on ramps there would be no chance of the engine moving?
sounds like a plan rob.. always making me spend money.. i also need to talk to you about the revo MQB as i want one of them too! :)
Reactions: Rob2k68
Haha LoL I'm a bad influence :friends:
Easier if on a four poster ramp so that if the engine does move you can see the holes out of line and know what way to move the engine - laying on your back and installing it at arms length is not the easiest if the engine moves not saying it will but for 2 out of 3 people I know that fitted it themselves it moved and was a bit of a pig to re-align. Now that we have that learning happy to share some tips over PM or on the phone mate.
Reactions: zippster
I took the easy install option of popping into my mechanic. Lifted on hoist and simple remove bolt, put mount in place and put bolt back in. 2 min job.
Reactions: Rob2k68
+1 for the 034 engine mount on a Black Friday sale!
I've glued to the screen for any deals.
Will report back if I have any luck. And vis verse I hope!
Reactions: Rob2k68
Reactions: Rob2k68
MKC, couldn't agree more. I got stung big delivery cost to Australia too. If I had looked more could have saved $20+ but oh well. It's still a cheap mod and does exactly what it's advertised to do.
Same one I went for :)
Reactions: Rob2k68
Got a somewhat decent screenshot of my engine mount after 4 takes, was getting kind of frustrated as I had to do it in 5/10mins. Sliding the cardboard in and out then checking the footage
Awaiting till Monday hear from 'Awesome' for a prices on some Eibach Sportlines
So till then I engine mount will also be hold
Reactions: Rob2k68
IMG 2133
IMG 2136
IMG 2137
Can any one suggest what version I need. 1st is mine, 2nd is version 1, 3rd is version 2 ?
Reactions: Rob2k68
Thanks gents part ordered.
In the new year my new clutch will be getting fitted, well get the bad weather out the way with.
Reactions: Rob2k68
Bumping this up - any more updates or thoughts since November 2016>?
I will be going stage 2 in my DSG S3 after the summer and I have revo engine and gearbox mounts in my 8P where I noticed a great difference
This is my first DSG car so not sure if that would make a difference or not but what is the general opinion? Do it??
What brand? 034? Revo?
I’ve recently replaced my 034 for the Revo dogbone mount and feel a decent improvement - smoother changes and seems to pick up quicker.
