73pop
Is any body running uprated ones or have any suggestions? This is the next on my list as i work to stage3.
Good black friday deal would be good
A good start would be the 034 motorsports engine mount insert. I have it on my Mk7R and tightened up the engine movement noticeably with no extra vibrations at all.
Think the guy with the red stage 3 car fitted this to his takes pressure of the transfer box think he saidAh, are you referring to the dogbone mount at the torque arm bushing strap to gearbox ?
have been toying with this also ? worth it? easy to fit? do i need a lift to fit one?
Thanks in advance
Yes do it !!
Only potential issue is if the engine moves when you remove the bolt to fit the 034 mount - you may then need a mate to pull from the back of the engine forward so that you can get it bolted back up. Much easier to do if off the ground on a ramp.
so if i drove up on ramps there would be no chance of the engine moving?
sounds like a plan rob.. always making me spend money.. i also need to talk to you about the revo MQB as i want one of them too!
https://store.034motorsport.com/mqb...golf-gti-r-8v-audi-a3-s3-billet-aluminum.html
Here is link to their site at sale price.
Same one I went forA good start would be the 034 motorsports engine mount insert. I have it on my Mk7R and tightened up the engine movement noticeably with no extra vibrations at all.
View attachment 110758 View attachment 110759 View attachment 110760
Can any one suggest what version I need. 1st is mine, 2nd is version 1, 3rd is version 2 ?
