A4 1.8T Quattro POWER LOSS @ 3-4K RPM
justin123
A4 1.8T Quattro (163BHP)
Manchester and London
ELLO AGAIN!!!
a while ago my engine management light came on and i took the car to audi to diagnose it.... they said nothing was wrong and it had come up "by accident".
I definateley noticed a power loss between 3-4k rpm but i thought i might be just imagining it. Then i started noticing other changes like getting from 80mph to 100mph was a real drag and took much longer to get to than before. Also the 100-120mph was a struggle and it would be near enough impossible to get up to 130mph.
This kind of speed was all tested on a rented airstrip by the way
so yeah in the past the car would go from 120-130 in around 10seconds with a full car and full boot. Now it will hardly get to 120.
My final blow was last night, i went to see my mate with a standard 1.8 A4 and he totally wiped me out and he wasnt even putting his foot down!!!
Audi said there was nothing wrong with the engine at all and there were no fault codes coming up (as i take it to my mechanic every 3 or 4 weeks)
I have read on some of the threads that there is a "limp mode" that the ecu can engage. could this be the problem? or maybe a faulty turbo? my mechanic recons the waste gate is getting blocked so i bought a K03s replacement. it has not been fitted yet but it will be soon enough before the end of nov so i will let everyone know how that gets on. I thought it may be the air/pressure sensor. I took the car to my mechanic about a week after taking it to audi and he said he got a fault code saying the cat is faulty so maybe this could have something to do with it??
For now i would really appreciate any help. even if it is just an idea. If any one else has had similar problems and solved it, please let me know.
THANKS!!!
get someone who knows VAG Com to look at the readings for the MAF etc, unlikely to be limp mode as you would struggle getting to 50 let alone 120!
if the waste gat ewas stuck shut you would be overboosting and definitely end up in limp mode, if it was stuck open (even partially) you would not see full boost.
A new turbo is a bit of overkill if the actuating rod is sticky, you can test how easy it is to open and close by hand
Also check out the N75 valve as these are known to go and also see if you have a vac leak as this will also kill the power. Other place to look at are the spark plugs check state of them and gapping.
