reverse mirror tilt
73pop
lancashire
This feature has stopped working on my car. I am just at Audi having a service so asked them to look at it but they are saying my car doesn't have that feature.
They are saying you have electric memory seats to have that function is that right??
It worked before so I am at a loss
So they're basically saying that you are lying?
Might have been set up after being sold?
I bought it 3 months old from Audi. It's not been plugged in anywhere to wipe it.
But yes they basically saying I am wrong!!
Nothing to do with seats - ridiculous.
You do need electric folding mirrors though.
And the control needs to be in the offside position.
Reactions: Rob2k68
Yes I have folding and it's set !! Still don't work. It used to. It stopped a few weeks ago
As above mirror dip comes with electronic folding mirror option - control knob needs to be set in NEARSIDE position assuming you're in the U.K. or to be safe set to the passenger side.
Reactions: pburv
It's definitely set to passengers side mirror
Reactions: Rob2k68
This cropped up recently one stopped working and Audi were basically calling the owner a liar - next thing they turned up at his house with an A5 Cabrio whilst they sorted it out in way of an apology. Wasn't that long ago.
Can't find it at the mo as I'm out walking the dogs.
Reactions: pburv
I have it and i dont have memory seats. My seats are manual. Unless someone before me changed the option via VCDS but i doubt it. cant you register on myaudi.com to see the details of your car? Dont forget you have to have the passenger side mirror selected on the dial bit to make it work. i accidentally turned to the middle and got in a faf about it not working!
Yes, sorry - I meant nearside, just said offside!!
Reactions: Rob2k68
on my audi it just says.
  • Door mirrors – electrically adjustable, folding and heated
They printed out a fill spec of the car. it doesn't mention the dipping function on there too?
Option 6XK
Door mirrors – auto-dimming on the driver's side, electrically adjustable, folding and heated. Also includes an automatic kerb view dipping function on the passenger side when reverse gear is selected. Only in combination with auto-dimming rear-view mirror (PU7) or Comfort package (WBI)
£250
Reactions: Rob2k68
i have 6xe mirrors on my care.. if i disconnect the battery will it effect my apr map?
Reactions: Rob2k68
Do you have folding or dimming mirrors...?
Reactions: Ormesome
it says this in the brochure!!
6XE
Door mirrors – electrically adjustable, folding and heated. Also includes an automatic kerb view dipping function on the passenger side when reverse gear is selected
Reactions: Rob2k68
Clearly the 'muppets' at your dealership haven't a clue....Go back and complain and get them to sort it...
Reactions: Rob2k68
What makes it worse is they wouldn't believe me when i told them it was working 3 weeks ago! seems if they can't fix it try to convince you you never had it
Reactions: pburv and Rob2k68
If you haven't already you could try to "reset" the dipped mirror position by setting the switch to passenger side while in reverse and manually adjusting to your required angle. It should remember again IIRC.
My car "forgot" the position once or twice, however mine is set by VCDS and might behave differently to standard functionality...
The map is safe with a disconnected battery so no worries there I've disconnected mine a few times with the map on.
Trying to re-learn its position sounds worth a try.
Reactions: pburv
will give this a try
once adjusted to the right angle do just set off or move the switch off the passenger mirror ???
Once adjusted flick the switch to the centre position to store the settings then back to passenger side and keep it there for as long as you want mirror tilt activated.
Tilt function automatically goes to normal position when you hit 10 or 15mph can't remember which or when you key off and take the keys out.
Reactions: pburv
thanks will try and report back
Reactions: Rob2k68 and pburv
tried this didn't work thanks tho.
Shame :-(
I may have mis-remembered the procedure... found this on a quick search, not sure if useful:
Seriously mate If I were you I would insist the dealer sorts it..If they are playing 'silly buggers' with you get in touch with Audi UK...
Reactions: Rob2k68
just took the battery off all is well now. think an email to the manager is next i think they thought i was trying to blag some free coding and ignored what i said
Reactions: pburv, aurian and Rob2k68
I have manual seats and manual folding Windows...electric mirrors not sure about heated...used VCDS and made sure I have my mirror switch in passenger side position... Video here...
Reactions: pburv
Folding windows ?????? ;o)
The VCDS mod is great if your car comes without electronic folding mirrors. As the mirror itself is missing some sensors that store the mirror dip position you may need to tweak the position every couple of months.
Reactions: TimWills28 and pburv
Glad you got it sorted !! Sounds like the car got confused and needed a quick reboot !
Yeah, would be interesting to hear what the dealership has to say for themselves.
Reactions: pburv
Folding windows??
Did Tim not tell you he was driving a Citroen 2CV....lol
Reactions: TimWills28 and Rob2k68
Haha Windows made of cardboard lol
Thought all was well but now the long button press dose not work, i noticed that i had left my roof open so trued to close it with key not working? looked in mmi settings everything if ticked to say its on. if i put the key in the lock turn it to unlock or lock windows go up and down. i remember when i had my v64motion there was a way of making it learn this function. dose anyone know if its possible to do this on an 8v?
Think you have to hold the switch up to raise the window manually but when it's at the top keep the switch help up in the same position for 10 seconds and it re learns the position of the windows. Something like that !
Reactions: pburv and 73pop
This was on 8p quite sure it's same on 8v
If not VCDS re - enabling is needed..weird that it should stop working once mirror dip was activated
Modifying a setting can sometimes affect other settings within a car with various "versions" of VCDS.
