Hi guys,
I have a strange issue with my Audi S3 8P1. When the car is first started from stone cold, the engine appears to make a random knocking / tapping sound which is difficult to locate. At first I thought it may be a tensioner problem, but this seems unlikely.
It only happens for about a minute then the sounds disappear. Also the car puts out a small puff of black smoke when started from cold or driving off from a cold start. I've had my local specialist check the car over and give it a diagnostic scan, but the only fault that showed was an air con fan sensor open-circuit. They never heard the sounds since they started the car, then drove it into a bay inside their garage. The noise never showed because it only happens the first minute of starting.
I had the car remapped a while back, however I removed the map one month later as the clutch started slipping. I replaced it with Sachs organic performance clutch and OEM DMF. The clutch now has just over 2000 miles of running in.
Has anybody experienced something similar to this before or have any ideas what it could be? I'm wondering if it could be oil pressure being a touch low until engine oil has warmed slightly? I plan to book the car into my local Audi garage when possible.
I have uploaded a video of the sound to YouTube:
