Hi all, can anybody please tell me if the rear indicators on my 65 plate Sepang Blue SQ5 can be altered using vag com so they ascend outwards like ive seen on newer models in the audi range, thanks Steve.
Would need to check part numbers 1st as they maybe different for the lights given how they're controlled separately & wiring, plus a module may need upgrading to cater for them to operate that way, needs r&d.
This has been asked a lot over on the Q5 forum and the consensus is no they can't. You would need the entire unit which currently is only in the Q3 and not got to the Q5 yet.
Has anybody else managed to find out anything? I have seemed to hit a 'brick wall' I can't find out even if anybody does any aftermarket versions or not. There must be a solution, or if not, there is defiantly a whole in the market for somebody to make a killing.
