- Joined
- Feb 5, 2016
- Messages
- 7
- Reaction score
- 0
- Points
- 1
- Age
- 31
Hello guys!
I have bought Audi a3 1.8T AGU engine code. The car had broke the timing belt and when I took it was into parts (process of recovery, but the owner had not time and money to continue). After I bought the car friend of mine helped me replace the broken stuff and assemble everything together.
Now I have following problems:
1.Temperature gauge on the instrument cluster shows a bit after the middle seems like 95 degrees (not sure is it a big problem but according to VCDS temperature is fine ) have tried to change the temperature sensor same problem.
2. The engine does not feel well. After engine is started staying in idle feels like it misfire (while attached to VCDS the showed rpms were 880 and when it was that misfire it showed 840 then back up to 880 like this all the time)
3. While driving most of the time I feel "lag" while accelerating (not sure is it caused by the 2nd problem). But I have replaced the spark plugs, ignition module, Forge Diverter Splitter Valve, also changed some of the vacuums hoses(picture below). Maybe good input will be VCDS readings but I do not have any idea which exactly will be useful. Engine is not throwing any error codes except for the ABS and the CLIMA.
I do not own a boost gauge at the moment (have ordered one still waiting for it to arrive )
I am studying in Denmark and it is crazy expensive to bring the car to mechanic, so I hope you can help me out with that.
