EPS and steering assist loss after a battery change
sanpat
Few days ago my battery died (2008 1.6 Audi A3 8P) and had breakdown replace it with a new one. Unfortunately EPS and steering sensor fault lights appeared. Faults as below.
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.078 H08 1901
Shop #: WSC 02069 000 90108
VCID: 36683A5C38C1
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
On trying to calibrate sensor and putting on Basic settings for steering assist using instructions from Ross-Tech- turned steering left then right and then drove few miles but no help. In fact now steering appears to have lost power and very stiff. See new fault below
Address 03: ABS Brakes Labels: 1K0-614-517-MK60-F.lbl
Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Component: ESP FRONT MK60-AT 0102
Revision: 00H14001
Coding: 0021121
Shop #: WSC 06314 000 00000
VCID: 68D4A42422F5
1 Fault Found:
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
2 Faults Found:
02546 - Steering Limit Stop
Freeze Frame:
Mileage: 74670 km
Temperature: 36.0°C
Voltage: 14.20 V
Voltage: 14.00 V
000 - -
Freeze Frame:
The Steering angle field in group 007 in measuring blocks of steering assist controller shows 0.00 regardless of steering wheel!
Any help appreciated. I am a noob here so sorry for any errors. Thanks for help in advance
Been doing that last few days over and over and over again. No joy
Do I need to get a new sensor?
Did you try and delete the error code in vcds?
Seems odd that changing your battery cause this issue?
I have already tried deleting codes but keep comming back. Full reset? How would you do this even if VAG specialist
Remove the two battery cables and short them together with a spanner, away from the battery itself.Should work then after reconnecting the battery
Tried this just now and even disconnected for good 30 min before connecting but still not working
Any other suggestions greatly appreciated
@LEE69 went for a drive as well
@Orange225 thats procedure I did followed that guide exactly before posting here
Trying to put basic settings on lost power to steering- before that just had the dashboard lights
May need new sensor ?
Anyone know a good vag specialist in south?
@sanpat can you please explain did you found fault? I have the same problem with my Skoda and cant find what is the problem...? It is old post I know but if you remember what happend it can help me maybe to solve the problem...
