Riccoshire
- Joined
- Aug 8, 2015
- Messages
- 3
- Reaction score
- 0
- Points
- 1
Here's my problem with my a4 b6 avant. The remote fob has never worked since I've had the car. I replaced the battery and tried to reprogramme(various methods but none worked). The only way to get into the car is to manually insert key In drivers side, turn to the right(no noise),then insert the key and turn on ignition to unlock all the doors. To lock the car is key in the lock, turn it to the left, it locks all the doors and flashes hazards once. However I noticed the led on the door card flashes for about 10 seconds, goes SOLID red for about 30 seconds (maybe even more)then settles down to a steady flash. There is no chirp from the alarm siren, but when I looked at it the usual battery explosion had happened and(I reckon) completely destroyed the circuit board, it's in a mess. I pulled the passenger carpet up, had a look at the module and it was completely dry and to be fair it looked brand new. Everything else is working in the doors, windows working fine, mirrors working, door markers and internal locking. The only thing that happens sometimes is the speakers cut out/crackle slightly,(drivers and passengers). I'm wondering if the alarm siren is causing the problem and sending a signal back and telling the car there's a problem. Bit lost atm. It's an inconvenience at best, but most of the car is up together and would like this working as it did come with remote locking in the first place. Thank-you all.
