Failed CV Joints (DriveShaft)
DTYME83
As some of you are probably aware the inner rear cv joint on the S1 is a massive weak spot. My car is currently in development with Track-Tek having a stronger more robust joint /shaft made up. As development unfolds I will update the thread.
Pictures below of what happens when it breaks and as some of you have noticed it effects the haldex
DTYME83
Reactions: AGee, Scottien and J-Dan
Spoke with Nick @ track-tek today and hopefully he should have something positive to tell by the end of the week fingers crossed
DTYME83
Reactions: ChrisG.
Yay! He didn't reply to my enquiry on Facebook, but I'll just keep an eye on this thread since you are the man-in-the-know.
Reactions: Scottien and DTYME83
Just had the nearside back wheel off and mine, ,mercifully, seems to be ok
superchips are quoting 469 Nm from bluefin !
Reactions: DTYME83
Mine is 475 Nm converted from 351 ft/lb
Reactions: Scottien, ChrisG. and Miguel Freitas
Things are on the up parts are now coming off the car let's see what goes in its place
DTYME83
Reactions: ChrisG., Scottien and Miguel Freitas
Quick update
Golf R /S3 Propshaft added to the development process. Hopefully this should prevent the car from throwing its toys it the pram when more power is added. As my guess is once the shafts are strengthened the problem is likely to move to the propshaft
DTYME83
Reactions: Miguel Freitas, ChrisG., Scottien and 1 other person
Hi,
any news? Thanks
Caught up with Track-Tek yesterday and there may be potentially two options
Option 1 - Replace the CV joints using the current shafts
Option 2 - Replace the shafts and CV joints.
Hopefully i should have a solid answer today or at least in the next few days
DTYME83
Caught up with Track-Tek today.
New shafts will be made this week and should be fitted to the car early next week.
If anyone is interested in please feel free to DM, as I sure there will be a minimum run on the manufacturing process.
DTYME83
DTYME83
Can you have an estimation on the cost? They will do front and rear shafts?
As soon as I have an idea on cost I will update you, I relation to the fronts it was raised originally and at present they see no reason to do the front as they are pretty solid but I will however ask the question.
DTYME83
Hey... Back with some pics about the APR installation!
After some hard work here is the final and awsome result!!
PS - space is non existing!!!
Reactions: DTYME83
Development has taken a little longer than I had hoped, however new shafts should arrive on wednesday.
DTYME83
Reactions: Ian Whiffen and Miguel Freitas
Any estimation on cost?
btw (off-topic): I did a test with my current setup on road from 0 - 62 mph and I could do 4.7s
Do you have any idea of avg values from other S1?
Thanks,
Miguel Freitas
I should know cost by the end to beginning of next week, would you like me to put down for a set
let me know when you have the cost and if not super high then I will want since the car is stupidly fast and torque is much higher!
I will go to dyno during this week or next week.
Hi, I'm a newbie here. Your bad experience may worry most of us.
As you broke 2 CV joints, don't you think there might be a disfunction on your car ?
I mean that CV joints are usually designed for twice the maximum torque at the Wheel. And torque high values are reached during "accidental phase" when ESC system is working (wheel brake tightened). I was wondering if a disfunction of a sensor or a usual ESC activation in your utilization may explain... Anyway for a track use, I think more secure to switch off the ESC, specially with a remap.
The rear shafts on the S1 are exceptionally small compared to the shafts on the A3/S3 and I am not the only one that has experienced this issue, so my take on it is that the car can't take the additional power.
DTYME83
Sure you're right, must be a weakpoint of the car as it occured for several people. Now considering engine torque improvement (370Nm to 470Nm): with S1 full gearbox ratio in first gear, if i'm right max output torque may vary from 5000Nm to 6300Nm. Only half of this can be transfered to rear axle what means that each rear CV joint should see max 1250 Nm(stock) and 1575Nm(tuned), if part is well designed there mustn't be a problem. Situations where CV joint will see more is a recovery of grip after wheel slip OR when braking system is activated on one wheel by ESC what leads to a torque pic on the braked Wheel and hence full axle torque is transfered to the other CV joint. On my car, at only 6000 miles, a complaint has been raised by previous owner because rear brake discs were anormally used what make me think ESC is regularly activated.
My conclusion is: sure a tuned car will increase failure occurement but to reduce risk we may switch off the ESC for each track session or hard driving (not on straight road). Avoid 1st gear full acceleration specially on slippery roads when wheels may slip and after recover grip. To go further, should be great to know what driver profiles have people who met the failure. Sorry for long message and good luck for your upgrade ;-)
Reactions: Scottien, gmeroni and DTYME83
Parts are being fitted this week
Hello again,
do you have the parts already fitted into your car?
I received today the TTE470 I will be testing in my car after this thursday dyno with my orignal turbo with hybrid solution from CR Turbos in Portugal.
If everything goes well I will then fit the TTE470 and do another run in some weeks.
Assuming I will achieve great power results I really need the CV joints :D
Hello again,
Still a work in progress but it's almost there
DTYME83
Did you consider fitting the TTE525R?
A complete set of shafts and cv joints should be produced in the next 2 - 3 weeks would like me to add you to the list
DTYME83
