Mark_Reso2
- Joined
- Mar 23, 2016
- Messages
- 2
- Reaction score
- 0
- Points
- 1
Hey Guys,
I've recently had the Emission Control System light on my dashboard turn on briefly in my Audi A4 Cabriolet (2004, V6).*
It turns on and then off again.
I've read the fault codes but am not that knowledgable so was hoping you guys could give me an idea what I'd have to expect if I were to bring it down to a mechanic. A vague idea whether it's a minor issue or potentially expensive would be great. And whether there is any DIY I could do on it?
When I delete the codes some of them come back usually the 7 below.
The car drives a bit jerky sometimes but overall works relatively alright. I've stopped driving it for now until I find out more.
Looking forward to any help/advice I can get. Thanks guys.
Please find the fault codes listed below with a link to Ross-tech:
16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
http://wiki.ross-tech.com/wiki/index...4/P0300/000768
16685/P0301/000769 - Cylinder 1 Misfire Detected
http://wiki.ross-tech.com/wiki/index...5/P0301/000769
16686/P0302/000770 - Cylinder 2 Misfire Detected
http://wiki.ross-tech.com/wiki/index...6/P0302/000770
16687/P0303/000771 - Cylinder 3 Misfire Detected
http://wiki.ross-tech.com/wiki/index...7/P0303/000771
16688/P0304/000772 - Cylinder 4 Misfire Detected
http://wiki.ross-tech.com/wiki/index...8/P0304/000772
16689/P0305/000773 - Cylinder 5 Misfire Detected
http://wiki.ross-tech.com/wiki/index...9/P0305/000773
16690/P0306/000774 - Cylinder 6 Misfire Detected
http://wiki.ross-tech.com/wiki/index...0/P0306/000774
Recently when trying to check it I've also had the following code show up instead of the Cylinder 4 misfire:
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
http://wiki.ross-tech.com/wiki/index...5/P0441/001089
Last but not least occasionally have gotten the following fault codes as well:
18149 - I believe this one means "Clutch Pressure Adaptation: Limit Reached"
18181 I believe this one means "Hydraulic Pressure Sensor 1 too large"
If you require any other information please let me know.
Thanks again!
-Mark
Thanks again!
-Mark
