- Joined
- Aug 3, 2015
- Messages
- 392
- Reaction score
- 44
- Points
- 28
Hi all,
So far i have done the below on my car:
oil pick up
balance shaft sprocket
thermostat
water pump
timing belt
clutch switch
PCV valve
DV valve
N75 valve
N80 valve
the next things i want to do are the below:
get to the bottom of my coolant leak?!
there is a slight whining at 30 mph, it sounds like its coming from the front right of the car however after looking into this i think it could be the pinion bearing so need to get this sorted.
figure out why my reverse parking isnt working
fit new stereo/RNS-E/Xtrons unit
do some general maintenance.
With regards to general maintenance just wondering what other people would do? going to do the standard oil and spark plugs and air filter. ive already got a fuel filter to fit aswell. sorry for being niave but whats the reason for the pollen filter? does this need replacing?
Darren
oil pick up
thermostat
water pump
timing belt
clutch switch
PCV valve
DV valve
N75 valve
N80 valve
Darren
