How come Audi only put the Speedo to 160 on the S4? My sat nav did the rest...
I need some of these!
Yes indeed.Probably another cost cutting exercise on this so-called luxury car.
Did you notice if the speedo showed roughly the same speed as the sat nat was indicating (before the speedo maxxed out)? Or was it around 10% more? The rumour is that speedos are designed to overstate speed.
Although I'd imagine you might not have compared this at the time seeing as you must have been concentrating hard on the Autobahn or a track.
Loving that redline...!RS4 has 200 on the dial, and speedo is all electronic so the spacing is just to make it clear and readable under standard conditions, the section most people drive in, after that the detail is not as important and to allow 0 -200 (or 160 on the S4) in the circle it changes to 20mph per section.
if I was doing that, my oil temp would have gone up to 120 degrees celcius..
Does the car get near it tho?but then again.. my speedo goes up to 300kph..
Well that's the problem you see :Get some decent oil in it and a decent filter.
Highest mine goes is 110 max.
Castrol is the way to go. Mines due soon.
1,000 miles in 7 months
