What Detailing / Car Care Products Have You Bought / Ordered Today?
stupid question, but how do you use these? Is it a case of spraying a bit in car after clean?
Reactions: V6_Man
Time to tackle my cruddy pipes - car doesn’t look properly clean with dirty a-holes
Tbh, given the reviews I bought one a few months ago I was really disappointed with Autosol. I have used it only three times and decided not to anymore. I tried both if them recently on the S4s tips and Autoglym managed to clean the tips better than Autosol including the shine. Autosol required a lot more elbow grease and the results were sub-par
Yes. Few sprays under the seats and occasionally in the vents.
Reactions: NevMan and Jimbob76
I was actually considering new tail pipes as they were so crappy. Then someone on here suggested spraying them with WD40, leave a while to soak in. Then apply Autosol , work in with wire wool. Apply some more Autosol, leave a while longer and then buff with MF.... Viola.... Tailpipes like new.
Sent from my HTC 10 using Tapatalk
Reactions: NevMan, V6_Man and Jimbob76
any pics?
Folks, need some suggestions. Planning on re-correcting minor swirls on the A3 so will be using combination of products between Scholl S20, S40 and Sonax Profline along with CH HL Green and White pads.
I am after a cleanser fluid after the above and before I apply sealent and wax the car and can't decide between:
- BH Cleanser Fluid, and
- CarPro Eraser
Which one would you guys recommend between the both?
think both would be pretty good, like their other products but I have gtechnic panel wipe, which has done the job for me, admittedly I have only done door shuts after mini da polish ahead of ceramic
Reactions: V6_Man and Jassyo06
Bilt hamber as l said before, l didn't rate the carpro eraser when l done young matt sedge car, yeah l used it but also sprayed a ipa mix on the panels afterwards
Reactions: V6_Man
Cheers @q5man and @jassyo06. I already Gtechniq Panel Wipe but now looking at stripping off everything (all 13/14 layers of waxes/polishes etc).
Also, have you tried Gtechniq C6 -Matte Dash, is it any good?
Reactions: Jassyo06
I've used Dodo Juice Leather Cleaner and Sealent and really like it. Pics FYI
Reactions: Jassyo06 and Jimbob76
**** av used it 5 minutes ago lol for the first time mate and to perfectly honest it does clean very well but spraying it on to the leather can get a messy ie over spray on the centre consul etc etc, l used a brush along with it and it doesn't foam that's something i like as the dirt is gathered up in the suds then it's just a wipe off, l then tried spraying it on to a damp cloth, got better results but a cloth doesn't remove all the grime/oils off the leather in my opinion especially on a steering wheel, l still recommend my fave and that's valet pro leather soap it's the best l have used and the best to work with, colour lock came very close to it but it doesn't leave that new oem matte look
Combine valet pro leather soap and colourlock leather shield =this is a ant friction Sealant
Is my perfect leather cleaning kit
Reactions: Jimbob76 and NevMan
I haven't used the gtechniq matte dash but it's on the list mate as l think the dashboard etc etc just needs a little lift back to the new car just out of the factory look gyeon do a version as well
Reactions: NevMan and V6_Man
Chemical guys do a shampoo that'll strip off all your layers, clean slate as it's known
Panel will do the job but you'll use more of it than you would bilt hamber so not as effective or as economic as bilt hamber cleansing fluid
Cheers @Tashfeen - anyone who is ever after a lovingly owned B8.5 S4 could do a lot worse than buying from you my friend. I still hurt a little when I see what Audi did to your boot lid . Any news on getting that sorted?
Ha! Big Brother is watching you @jassyo06 ! Thank you both for the recommendations - appreciate it gentlemen. The missus had some ***** telly to catch-up on tonight, which gave me a good excuse to get an order in for some new stuff....
****** pain to find somewhere that stocked everything I wanted in 1 order and with a discount code, but managed it in the end. Had to order Colourlock Leather Shield off flea bay separately.
And before you ask @jassyo06, yes I did order some Fireball tyre shine just a couple of weeks ago - but made the mistake of taking the nozzle off to have a sniff, left it on the drive while I went to make a cuppa, and next door’s cat kicked it over and spilt the lot on my drive . Next door’s cat will soon be my next pair of slippers.
Reactions: Jassyo06
Pmsl.... Oh dear if that had happened to me l would have had the air rifle oot in a covert night time recon looking for that cat mate lol
But seriously what a high quality list of products you got mate
Here's one for ya at last Saturdays car wash day l decided to use BH auto wheels now l carefully sprayed it on to one of my alloys... Etc etc only one tiny spot of fallout was revealed l kind of knew this as l ain't a heavy on the brakes person hence l never buy wheel cleaners, but l used the next door neighbours vx Astra for the test, his alloys are bright silver painted things that hadn't been cleaned properly since it was new my god what ja ob BH wheel cleaner done and l had only blasted them with a pressure washer prior to spraying lol l can see why this product is popular but l always keep my alloys in tip top condition besides l think it's ****** expensive, it's for peeps who hate spending time washing alloys
Reactions: Jimbob76
Tip hold the leather brush under the hot water tap for a couple of seconds.... Get to the car and apply the soap to the brush and clean away then buff off with a largish cloth, same goes with the steering wheel but cover over the dashboard with a large towel or something prior to cleaning .... Product does flick off the leather brush
Reactions: V6_Man, Alan999, Jimbob76 and 1 other person
On offer in Halfords £19 down from £39 apparently.
Auto finesse Iron Out £9
2 litre pump spray from Toolstation £6.45
Reactions: Jassyo06
Nice one mate love a bargain myself but hard to come by these days
Reactions: NevMan and BarryG79
I usually use BH Auto Wheel which i have grown to love but on the way to jet wash I realised i had finished my bottle. Swung by Halfords and picked up AF Imperial wheel cleaner. While it didn’t have the same visible reaction as BH, with a little agitation i was actually pretty impressed with the end result.
And this was a particularly dirty set of brake dust covered wheels.
On a side note, i see Polishedbliss has had a total revamp - seems they are doing a points system rather than possible special offers. The points seem to get you 5p off per point etc in the lowest tier.
Site does look good though.
Reactions: V6_Man, Jassyo06 and NevMan
l find them expensive as are CYC....you've gotta spend £100 or more for free delivery with CYC,but they are the only one's that sell both Gyeon and Gtechniq products,ultimate finish prices are hyped upped as well,in particular their machine polishers there more expensive than anyone else
On one sale from CYC....l spent a £154 and got £6....worth of points......about 4-5% discount pretty guff as it does'nt increase no matter what how much you spend
one of the best sites l found for reasonable prices is in2detailing but their range is limited, hopefully it'll grow...for example the cordless Flex xfe 7-15 l was offered it at £510 bangers......from lmran...which is a £100 bangers less than most the others selling it
Reactions: V6_Man
Cheers @Tashfeen - anyone who is ever after a lovingly owned B8.5 S4 could do a lot worse than buying from you my friend. I still hurt a little when I see what Audi did to your boot lid . Any news on getting that sorted? .
Cheers mate. After nearly 25 emails and 1 month it is going back to Nick @detail My Car on 21st for boot repaint as well as re-correction/coating. Patience was the key. The Service Advisor was ****** good and his Service Manager an ar*eho*e.
Nice purchase buddy
Reactions: Jimbob76
That is some difference. How you finding the Flex products? Glad you went for them?
At their expense I hope mate? Well done for persevering and not letting it go. Your pride and joy will be as good as new in no time. Bet you’ve been parking so that you don’t have to approach her from the rear (so to speak!).
Clean Your Car weren’t the cheapest, but not too bad and they had all but one of the products on my shopping list. As well as ‘points’ earned I’ve also been given a 7.5% off my next order discount code - so pretty happy overall.
Subscribed to the Forensic Detailing Channel on ‘The YouTube’ today, and had a gander at their beginners guide to using a DAS6 Pro dual action machine polisher. Pandora’s Box well and truly opened. Now on my wish list for Christmas and will undoubtedly take my OCD (and detailing spends) to the next level . Looks to be plenty of good content on their channel to educate me over the dark winter evenings between now and then . Question - the DAS6 Pro comes with a 5 inch backing plate, and you can buy a 3 inch backing plate to go with it as well, so on this basis will one DA with these two backing plates cover 99% of my needs (and avoid the need to also get my hands on a mini DA)?
Keeping up with you boys ain’t a cheap pass-time !
Reactions: Jassyo06 and Alan999
I have never had to spend 100 pound for free delivery on polished bliss they must not like you
I’m sure waxing your wheels with Fireball Fusion £80+ wax helps mate lol!
Seriously though, tip - I’ve found that BH Auto Wheels is SERIOUSLY concentrated stuff and can therefore take diluting with water 50/50 and still work VERY well on regularly maintained wheels - on that basis it works out good VFM and helps add some good suds to when you wash the wheels after you’ve used regular auto wash for the bodywork. So you’ve potentially bought 2 litres of the stuff, not 1 mate I like it as I NEVER take the pressure washer to my wheels - too paranoid about the diamond cut finish getting the dreaded white-worm.
Reactions: Jassyo06 and NevMan
I spent the morning using Meguiars Ultimate polish and Meguiars Deep Crystal Carnauba wax on the wife's A Class
Reactions: V6_Man, NevMan and Sandra
Cheers for the info mate l will dilute it as l said i am a novice when it comes to wheel cleaners curiosity made me buy but won't use often at all
Went and bought some products from In2detaling 3 products, now what happened went as follows l clicked and paid =payment was confirmed, but straight afterwards the site said you need to choose a delivery option, but that was automatically done by the order being over £50 free delivery 3-4 days,so l ends up with no email confirming payment/receipt and no record of the order in my account, its still in my "basket" but the money has been taken out of my account !! strange indeed
Got some Angelwax Enigma shampoo, Enigma QD and cleanliness well i hope l have lol orderd these products just to make maintenance washes that bit easier on my mums, avrils cars carrying a bit of a shoulder injury atm .. ****** awful it is so not been detailing a lot recently
I meant that CYC=over £100 free delivery l have never purchased anything from polished bliss mate because of the layout of the site and they are a bit expensive
Ahh ok I got you
plenty of websites now so can buy from whoever you like best
Be interesting to see what you think of the Angelwax products as you always critical on products
If a product costs a few bob mate well l think they're actually putting themselves up there for criticism
They're in preparation for winter mate just wash n go type of products
Reactions: Audib5fan
True true I get what you saying hopefully the order gets sorted out
Reactions: Jassyo06
I feel your pain with the shoulder injury mate. Did my rotator cuff a few months back, took a lot of physio to sort out.
I'll be interested to hear a review of the Angelwax enigma shampoo and QD
Reactions: NevMan and Jassyo06
