http://www.ebay.co.uk/itm/10-x-Unde...540588?hash=item339d5e626c:g:hlAAAOSwKrhVXx6R There you go mate.Do you have a link for the under tray fixings, some of mine could do with replacing.
Ok it's had its day anyway and is a PITA to clean around. When I get a moment I will polish it off.Loose the A4 logo too it will make the rear more tidy.
Different temperature bulbs or a bulb on its way can give off different colours mate
I had two off ebay mate and on them the clips broke on them nightmare. Same happened to my mate as wellRandom picture from the weekend.
Then tonight I got angry because I was trial fitting a Chinese eBay special front grille with honeycombe to match my votex but I barely pushed on it and half the clips smashed. Anyway:
Not sure whether to try and send it for refund but I got it toward the end of last summer so it might be too late.
iam getting the same issue with my drivers side door speaker. looks like ill have to pull mine. and check the wire. thank you for a great write up mate..And pulled some through (annoying white clips to tackle first)
There were 2 clearly clean sheared wires, +12v & ground. Hence the arcing.
Wanted to have a proper look so I took a bit of the black wrap off and moved the flex further along
I found more damage to wires, only two didn't have any damage. The rest had tears in the insulation and a few had started to fray.
Decided it would be easier to work on with it removed so took the loom out the door through the door shut end, hardest part was releasing the ****ing connector from the door latch/lock.
Got it on the trusty work bench
I soldered in some fresh wire for the broken wires, gave them all some shrink wrap, then insulating tape and a tiny dab of grease to help them move past each other.
And done.
Refitting was just reversal of removal. With it all back together I plugged everything back in to the loom and gave it a go. Door locked and unlocked again . Interior light and dash recognised door as open and closed, great I thought. Started her up, no windows/mirror control/total closure still.
Now I spent the next two hours on this, trawling the search, thread after thread of broken wires in the door flex. Strangely I noticed you could now open the other 3 windows locally where as you couldn't before. I checked over all connections, had the loom back off to bell out continuity with the meter. All ok. Decided it must be a faulty driver's door control module which is attached to the bottom of the window motor.
Great work! Love those 19's on the B6 so much.
great write up so far mate i remember doing my cam belt feels like your stripping stuff out forever
Lol gotta be prepared!
Although, have you seen my rusty arch coming through? Look back through the pics and you see the paints come off that won't be sorted in time
Find a good local body shop! I've seen your car west hunsbury way! I know a good one near you
Thanks for the comments
I live near the top shop mate, where are you? Where's the spray shop, I'd much rather go off of a recommendation than go searching blindly, you often get mugged off that way.
