Thanks for the welcome, I will sort out a pic tomorrow - after some more work and a clean.
From what I have learnt in the first few days is - I have a:
2001 S3 Quattro AMK ECU re-mapped to 243 (apparently) - it has an under bonnet variable booster tap (which I will test tomorrow) - and carbon can airbox
Its the S3 non metallic blue
I have already changed the plugs after it developed a misfire, one of them is in my avatar, I think this also caused the accompanying coil failure (which looked brand new)
It has a stylish leather and blue suede interior
120K miles
a tiny amount of rust on o/s wheel arch
a hanging door blade on driver side, will drill that off tomorrow - to check the runners etc.
the handbrake is poor
it feels weird on a private road > 100 (wheel bearing? brake binding? hopefully not a 4WD issue)
the ABS/ESP light occasionally comes on (don't have a vagcom reader yet, only Bluetooth ODBII and Android Torque) - seen something about an ABS module dry solder joints and dremel DIY to fix "terminal 30 voltage" issue..
CD Player (Audi Symphony) doesn't play CDs - ERR1
If it is stationary with the engine running, I am sure some smoke is somehow coming into the cabin, it smells of oil burning but there is no oil leaks or smell outside.
Welcome to the forum stuart, you'll love our forum its the best for audis as sandra said head over to the 8L section for the best knowlege regarding your S3
