Trying to figure out what's going on with my 2001 AMK S3 with 71K miles. It's a TBW model.
I am the only owner and other than fitting aero-wipers it's stock; no remaps or performance upgrades fitted.
It's my daily-driver and gets a 15-20 mile round trip to/from work during the week (mixture of city traffic and a brief jaunt on a fast A-road) with a longer journey (motorway driving) every couple of weeks.
A couple of months ago I noticed that the the Emissions Warning Light (the one shaped like an engine) came on orange and stayed on. I've tried the usual fixes (see below) and cleared the warnings, but the light comes back on again after a couple of drives.
The engine fires up first time, but then runs unevenly (misfires?) for the first 30 seconds or so, then runs unevenly; underpowered, feels like it might stall when I apply throttle. It takes a while for the engine to warm up, but then it runs OK. I've taken to setting the climate controls to "ECO" to reduce the load on the engine when it starts and waiting until the engine has warmed up before turning it back to "AIRCON".
I've cleaned the MAF, Air Intake Temperature Sensor, the Throttle Body (which was filthy) and checked the hoses for obvious leaks and wiring (such that I can get to) for obvious breaks. Have also run a bottle of Cata-clean through the engine. The engine does now idle smoother when warm, but still runs poor on a cold start, particularly if the ambient temperature is cool; I didn't notice it much when the weather was warmer, but now the weather has turned cooler, it's struggling more.
Error codes suggest a fault with the O2 (Lambda) sensors (plural?), but I'm not sure where they are or how to go about replacing them. Quick check on eBay suggests that it's not a cheap part to go replacing on a whim.
There is also an intermittent fault code for a Break Pressure Release Solenoid. Have not noticed any issues with breaking, other than the brakes squealing under light breaking; the car still stops OK. The brakes work fine under heavy braking without any noise. Have standard Audi disks and pads fitted.
Thanks,
Mark
Thanks,
Mark
Code:
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01: Engine
Controller: 8N0 906 018 J
Component: 1.8L R4/5VT G 0004
Coding: 10710
Shop #: WSC 01236
WAUZZZ8LZ11003345 AUZ7Z0A1839630
4 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 -- 35-10 - - - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 -- 35-10 - - - Intermittent
16701 - Rough-Road Hardware Not Present
P0317 -- 35-10 - - - Intermittent
17540 - Oxygen (Lambda) Sensor Heating: B1&B2 S1: Heating Circuit Short to Plus
P1132 -- 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 01236
1 Fault Found:
00812 - Brake Pressure Release Solenoid (F84)
35-10 -- - - Intermittent
