I opened one up back in 2013 when it was a new car, I looked in the normal place under the steering wheel and it was not their, empty, elsawin says its up their but car in the diagram was LGD and the picture showed its up their, so I tried to remove the glove box but failed, the car was not in for work, I just wanted to see so gave up.
So if nothing under the steering wheel then remove the glove box and it could be there.
Trups
Trups
I have some upgraded footwell bulbs coming in this month fingers crossed so they are brighter the Audi ones and are a direct swap.
Trups
I have the rear ones in stock, its the front ones I am waiting on as I had to pay to have a new bulb made as Audi decided to put the lamp from a A8 Door pocket in the footwell of this.
I will put a thread up in the 8V section when ready.
Trups
Do you have pics or how to, and is there any VCDS required? Might need to do this seeing as I have changed other lights to LED.
Ah no vcds.. I read in the other thread this may be required.. Cool I will maybe just buy the kit then and see if I can manage. Cheers
From these retro fit kits. Anyone know if the brightness can be adjusted in the mmi?
.Did it have the ground wire integrated into the connector, or did you have to connect the ground separately somewhere else?
Was it a standard connector? I ask, because I bought a loom from BKS a while ago and it has a circular lug for the ground.
What pin was live?, plug b pin 50?
Rear footwells are £8 plus £2.10 post.
Fronts to be confirmed as I don't know what they coming in at yet but rears I have plenty in stock.
Trups
I can get the full looms yes. Would need to see how much the connectors and lamps are.
Did you get the front and rear kit?
Trups
do you have a sport back then?
I can supply a rear kit that we could get to plug into the front so its all plug and play?
Trups
I would get the female connector and another male so a piggy back style loom.
Will call Audi on Monday to find out.
And some terminals would be back order so if you wanted them I couldn't give a time scale.
Hi bud.okay thats fine, I will have a set when you can get them just give me a message when there in and I will send you a payment
Hi bud.
All parts from Audi be in tomo so I can have them ready to post on Monday to you.
Trups
