The misfiring on my 1.8T seems to be turning into a bit of a saga.
I've changed the Plugs and Coilpacks. While that helped for a bit it the check engine light returned. The loom looked in a pretty sorry state so I took the forums advice and changed the coilpack look. (Properly, re-pinning the ECU etc. I've also replaced all the EGR pipes so its not this.
In terms of physical symptoms, the car is a bit jerky at low throttle when cold, and when accelerating, especially in 2nd gear it feels like the boost is fluctuating so the car accelerates hard, then not so hard, hard and then not so hard.
Interestingly it doesn't seem to do it when cold. Is this because the ECU limits the boost until the engine heats up?
I've tried unplugging the MAF, it doesn't drive much differently, but the revs do drop when I pull out the plug for it.
I've had a good tighten of all the hose clamps, there are no obvious leaks anywhere. I really want to avoid taking it to a garage if I can help it unless anyone knows of a specialist near Hull?
The error codes are:
17705 Pressure Drop between Turbo and Throttle Valve
17763 Cylinder 1 Ignition Open Circuit
17769 Cylinder 3 Ignition Open Circuit
17772 Cylinder 4 Ignition Open Circuit
17766 Cylinder 2 Ignition Open Circuit
