New Onwer Of Imola Yellow S3 :) Few Questions....
Craig-P
Carlisle
Hi,
I have recently just collected my Imola Yellow S3 and I'm loving it so much, There's a few questions that I have and hope some of you lot can answer them for me..?
Firstly what Is this button for, Does every S3 have It or..? (Pic below \/)
Also I have been reading about enabling hill hold and have checked my ABS controller and I have the following - 1K0907379AE ESP MK60EC1 H35 0106 I already have TPMS system can I enable hill hold..?
My S3 is a 03/09 build, And has Sat Nav which I presume will be the early version, Can I update to the later..?
Does the unit have a CD Changer..? What is the best way to play music in the vehicle, It has some kind of audio dock in the glovebox but doesn't look like anything I have seen before, Is it just designed for a Ipod or..?
Your hep is very appreciated guys
Craig
Mine has a multi changer in the glove box aux input by the handbrake and 2 sd card slots behind the screen,don't own any cd's so I just use the aux input
Hi
Don't know about the light button think it's to do with DRL's later cars have auto on the light rotary switch.
Not sure as no picture of your sat nav unit from memory it came with the AMI or 6 disc charger. I've attached an image of mine which is the AMI located in the upper r/c of the glove box, comes with 2 leads 1 for iPod/iPhone (asin picky) the other is for flash sticks. Hopefully this helps you.
That button is what is called as the CH/LH lights (coming home/leaving home lights) Nothing to do with DRL's. It allows the lights to switch on when you unlock the car and when you lock the car the lights remain on for a selected time. Its basically so you can see down the path or wherever your going when its dark.
Yeah worked it out now, Cheers.
Your just the man I'm after, I believe you can get me a RS3 grill..?
Can anyone else shed some info on my questions..?
Anyone know about the hill hold..? My AMI doesn't look like that ^ Its not built into the square frame/surround like yours is....?
